Home > Maintenance & Modifications > Electrical wiring advice needed
Page 2 of 3 <123>
Martin
Site Admin
Are you taking the feed from near the sidelight connector (or can you)?
For the "neatest" installation, build a small loom with a plug and socket, straight through except for the "T" off of the sidelight feed that you need.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #444877 10th Aug 2015 2:32pm
RRUK
Martin,
That's what I intend to do, I have a ready made mini loom with connectors so that if I need to remove the headlight I can disconnect the sidelight feed, leaving the newly attached loom in place. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #444878 10th Aug 2015 2:35pm
Martin
Site Admin
I am missing something or did you not mention that before, and if so what you asked isn't a problem now?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #444881 10th Aug 2015 2:40pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Martin, I guess you mean a "Y" loom with a plug/socket at both end so no need to splice the existing loom..?
I bought such a loom for just this purpose, or buy the plug/sockets and make your own. It's reversible then if you decide to take the lights out at a later stage.
Simon
Post #444892 10th Aug 2015 3:34pm
Martin
Site Admin
Precisely Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #444897 10th Aug 2015 3:43pm
RRUK
Laughing
All's well that ends well anyway 2016 D4 HSE
Post #444927 10th Aug 2015 4:55pm
couplands
So, it's not clear why you needed to splice into the existing side light harness if you are putting the "Y" cable in.
By this cable I mean you plug one end (the bottom of the Y) into the existing plug ( that goes to the existing side light) then plug on of the Ys to the existing side light and the other of the Ys to the new positioning light in your headlights. It's all plug and play.
Or is that what you did in the end..?
Simon
Post #444931 10th Aug 2015 5:06pm
RRUK
I don't have all the bits yet but yes, basically that's what I am doing, but I will be splicing the cables. Just a simple piggyback design you see..
A home made version of this:
http://www.mudstuff.co.uk/products/mud-stu...-loom.html
 2016 D4 HSE
Post #444954 10th Aug 2015 6:21pm
rustandoil
Cut the main wire and use a crimp to join it back together with two wires one side and one the other, use a crimp with adhesive lining when heated this will perfectly seal the joint Thumbs Up
Post #444973 10th Aug 2015 6:39pm
RRUK
That's just as permanent as me simply soldering a join and heat shrinking though, rather than a solution where I can unplug if I need to remove them. 2016 D4 HSE
Post #444988 10th Aug 2015 7:19pm
couplands
Good stuff, here are the ones I have...same sort of idea. Cost £22 delivered from Peter @ Nakatanenga
Simon
Post #444997 10th Aug 2015 8:03pm
munch90
Econoseal connectors
Post #444998 10th Aug 2015 8:09pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
T transition breakouts are available, but you have been given plenty of other workable solutions.
for example http://uk.farnell.com/te-connectivity-rayc...dp/1296869
http://www.te.com/usa-en/search.html?q=tra...e=products
Post #445006 10th Aug 2015 8:27pm
Martin
Site Admin
£13 each Shocked  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #445022 10th Aug 2015 9:27pm
apt100
TE make top quality stuff, often used in aerospace or military applications etc.
Probably not viable for the OP, but thought I would post it up for interest Thumbs Up
Post #445043 10th Aug 2015 10:17pm
Page 2 of 3 <123>
