Home > Puma (Tdci) > Slipping out of 1st Gear
TerryC
England 2007 Defender 90 2.5 TD CSW Belize Green
I have an early (07) TDCi with very low mileage (33k) that has developed a gear box problem whereby it is regularly jumping out of 1st gear. Is this a common problem and will it require a new gearbox to solve the problem?
Post #441801 30th Jul 2015 11:14pm
Not a common problem, and unfortunately it is almost certainly a selector problem or other internal problem in the box.
Post #441804 30th Jul 2015 11:23pm
TerryC
Many thanks Blackwolf. If it had been noted before it might have given me some idea of the work involved. So we won't know until we crack open the box…… Not the sort of mystery tour I was wanting, but presumably a reputable garage will make the necessary diagnosis and rectify. Thanks again
Post #441875 31st Jul 2015 10:37am
Often or not they are sent to specialist by dealers I would imagine due to the fact the are so intricate and time consuming.
Post #441879 31st Jul 2015 10:45am
It may be a relatively simple fault, such as a stuck or broken detent spring on the selector, but the complexity of a modern gearbox is such that most dealers and independents will simply change the whole gearbox (main box, not the whole gearbox/transfer box assembly, that is) for a reconditioned service exchange unit.
You could get in touch with Ashcroft Transmissions in Dunstable (Ashtrans on this forum) for advice. They are without doubt the leading independent experts on Landrover transmissions and I am sure will know if it is likely to be a simple or sinister fault.
Post #441886 31st Jul 2015 11:09am
pob1968
Just to add Ashcrofts will be able to fix it no doubt too rather than want to just swap the whole thing. 110 Hardtop
Post #442021 31st Jul 2015 7:29pm
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
When does it jump out? Under power - or on overrun/engine braking?
Post #442073 31st Jul 2015 10:54pm
