Home > Puma (Tdci) > Rear recovery?
kbf1981
Rear recovery?
Is something basic like this, suitable for a rear recovery point? - http://www.extreme4x4.co.uk/acatalog/REAR_RECOVERY_EYE.html
I've no tow bar on my MY15 and no intention of towing. Thanks!
Post #440779 27th Jul 2015 7:58pm
Dora
I think the description and pictures say it all!
Post #440821 27th Jul 2015 9:47pm
landy andy
I've had one of those, and it needs to be well fitted, don't just rely on the threaded inserts in the rear crossmember.
Andy
Post #440840 27th Jul 2015 11:09pm
leeds
Post #440844 27th Jul 2015 11:32pm
ericvv
Post #440852 28th Jul 2015 6:20am
jst
Yes Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #440855 28th Jul 2015 6:43am
bittersweet
2009 Defender 110 Puma 2.4 USW Santorini Black
Re: Rear recovery?
OP stated
Other 2 suggestions are cheaper, does not effect departure, easier to fit and fit better with OP needs www.4x4overlander.com
Post #440893 28th Jul 2015 9:00am
AndrewS
All the recovery training courses I have been on you are told NOT to use the tow bar or a single point.
You are supposed to use two recovery points, ideally located at the end of the chassis rails then a bridle and then the recovery line.
How many of you have seen a deformed rear cross-member as a result of 'enthusiastic recovery' ?
The rear cross member aint that thick, do the math a stuck defender could require lets say 3T to recover it, so 1.5T on two locations are better than one at 3T. 130's have feeling's as well you know Smile
Post #440945 28th Jul 2015 10:56am
Re: Rear recovery?
My issue with that is it's a closed loop so you will need to add something like a shackle to attach a rope; also it does not appear to be sold with the option of a backing plate which should be used if it's being attached to the rear crossmember.
Similar to what's been posted:
and note that it's been fitted with the reinforcement kit (that does not include a rear plate Confused ) - see here:
http://forum.lro.com/viewtopic.php?t=58180
Compare and contrast with the item in the OP's post and I think you can see which solution is fit for purpose when recovering heavily bogged vehicle - either yours or someone elses. Safety factor is the thing you want to have in mind.
Post #440989 28th Jul 2015 12:38pm
The purpose of the backing plate is to protect the crossmember from vertical or lateral loading on the coupling which will bend the crossmember (especially with attachments such as a NATO pintle where the vertical component of the load is a long way behind the crossmember and which can therefore produce significant bending loads).
The backing plate will provide very little, if any, benefit for a direct tensile load, and unless the OP indends getting a fully-laden vehicle monumentally bogged, the recovery attachment he is asking about will be completely adequate with no additional reinforcement when secured to the standard threaded inserts in the crossmember.
In my opinion if you load that device sufficient either to bend the crossmember, pull it clean out of the crossmember, or break the attachment point itself, then you are attempting a recovery which is well outside your abilities with no real understanding of what you are doing. For normal purposes that device will be wholly sufficient.
Post #441038 28th Jul 2015 2:23pm
kbf1981
leeds wrote:
So would this be better than what I've posted?
As above... I'm just after a simple solution for *if* I need mild recovery or to help someone else. E.g. a few weeks ago one of our small pallet trucks got stuck and all it would have required was a gentle tug (maybe 200kg force?) and that would have shifted it. Instead it took a lot more work!
Ditto I intend at some point to go off road and I'd like something to recover the vehicle should I ever get stuck.
No tow bar - no intention of towing. Presently looking at:
- rear recovery points
- rear tank guard
- front steering guard
- front recovery points
and trying to find the best options in terms of 1) what I like the look of, and 2) what will last well, be strong and effective, and 3) not require loads of work to get on.
How much is the black one above mate? Couldn't find a link on your site.
Post #441064 28th Jul 2015 3:47pm
blackwolf wrote:
The purpose of the backing plate is to protect the crossmember from vertical or lateral loading on the coupling which will bend the crossmember...
Yes it does that but it also serves to take shear loads across the joint by friction between the plates rather than by shear across the bolt shank with the consequence of bolt failure; and when in shear loading the bolt interface with the hole is compressively loaded (crushing).
I've yet to see a recovery where it resulted in a directly tensile loading.
Not sure what the changes are to the current rear cross members over earlier versions but I did find reference to an earlier recall:
"The continued development of the Defender model has included changes to the chassis rear cross member. A consequence of this development will require the fitting of additional load spreading plates for customers who have Defender 99 model Year vehicles with a tow hitch fitted directly to the rear cross member."
http://www.landrover-center.com/rsm/Defender-L316/15321
OP seems to be moving away from a basic solution now towards more of a Camel trophy plus spec. Once the off-road bug bites...
Post #441088 28th Jul 2015 5:13pm
jst
- rear tank guard
the one you posted is fine with fitting as below
this one is prob ££££££ more but it will be well made. then again so will the other one. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #441140 28th Jul 2015 7:43pm
GypsySamuraiAnt
Australia 2015 Defender 110 Puma 2.2 SW Indus Silver
Post #441166 28th Jul 2015 9:05pm
Neat, and very sturdy.
Based on what the OP has said, I'd be inclined to fit a 2'" receiver at the rear, a steering guard with a 2" receiver at the front, and carry a 2" shackle fitting that fits either.
Post #441206 28th Jul 2015 10:55pm
