![]() | Home > Puma (Tdci) > Puma, not starting and no dash |
first simple thing to try is to disconnect battery for 5 mins then reconnect and try it
Loud40 Member Since: 22 Jan 2014 Location: Pembrokeshire Posts: 8 ![]() ![]() |
Hi munch, tried that, checked all the fuses with a multimeter, and the relays, main, starting ect... Plus changed the ignition switch, but still no hope....
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I'd be looking for a broken earth strap. if as you say fuses are all intact...
Thanks for the help, ill have a little look after work
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 339 ![]() ![]() ![]() |
Did you check all the fuses in both fuse boxes and the large fuse in the drivers seat box?
Has any work been done on the vehicle recently? The (non) starting issue has the symptoms of an immobiliser fault. Check the plug in the rear of the instrument panel, IIRC the immobiliser/alarm connects to the engine ECU (EMS) via this and the EMS controls whether the starter operates. A problem with this connector or (hopefully not) with the instrument pack could cause the problems you are having. You say ODBII shows no faults, what code reader are you using, most generic ones only connect to the EMS. You need to check the instrument pack and alarm unit for fault codes as well. |
