![]() | Home > Maintenance & Modifications > Sealing the Windscreen |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
Hi
I am currently taking the opportunity to try and stem the water ingress on my 2004 110 SW. I have not yet tackled the windscreen (the fake hinges on the bulkhead were a major water leak source), I have used Sikaflex. Costs about 9 quid from Screwfix. It is easy to apply, but very very messy, lots of rags needed, and a drop of white spirit to clean up. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
I worked in the windscreen trade for many years...
It was very, very rare that anything was sealed glass to rubber, (it was rare to seal anything at all!), though rubber to body sealing is best. The glass to rubber seal is usually very good and never needs sealing. |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
what type/number of sikaflex did you use ? |
Gleaney Member Since: 03 Dec 2012 Location: Earth! Posts: 94 ![]() ![]() ![]() |
A major leak source on my Puma was the spongy foam that runs horizontally between the bulk head and the windscreen. So.....I got some Captain trollies creeping crack cure, waited for a dry day and applied the milky liquid onto the foam and let it soak in. I did this a couple of times over a couple of days. Leak gone! I have also applied it between the glass and the rubber on the windscreen for good measure. Hope this helps. Damn planet is short of Kryptonite !
Sika Sikaflex EBT + All weather sealant. I used black and ran it over the existing seals (after cleaning and when they were dry)
It supposedly remains flexible so shouldnt crack Wear disposable gloves and don't apply too much at a time |
what makes the defender windscreen surround so different from other cars as i have never had a windscreen go in any car i have owned....i havent checked is the surround ally or steel and are there huge undulations in the metal to let the water through..........Is it just that the windscreen in nearly vertical so less water is deflected off? |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1769 ![]() ![]() |
![]() Click image to enlarge worked for me - £3 a tube |
Barney12 Member Since: 09 Jun 2015 Location: South West Posts: 744 ![]() ![]() ![]() |
My 2014 90 Stationwagon does this. The inside does seem to be staying dry though. Surely can't be good for rust prevention though if the car is sat for a long time with water trapped? |
Thanks barney i was hoping for a few more comments as if it happens to everyone then its obviously by design and if not its a seal malfunction.......and i agree about the rust !
I would certainly like the views of others on this issue.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Yes opening the doors after rain causes a gush at the front
Thus it must be a "water feature"
sorry but i have just seen this ........if the seals are doing the job properly i would of thought the water should have been kept out...........surely if you dont use your defender for a week all the water will be lying at the bottom rotting the metal? |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5118 ![]() ![]() ![]() |
Defender seals doing a good job ![]() That's why there is such a good lucrative aftermarket supply of footwell repair panels. ![]() ![]() http://www.youtube.com/user/conwy1 |
