Home > Technical > Stub Axle Oil seal
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
Stub Axle Oil seal
I had oil leaking out from the stub axle, quite a small amount. This appears to have been caused by a blocked breather on the real axle.
On unblocking the breather no more oil is leaking from the stub axle.
I am now wondering if the stub axle oil seal is permanently damaged and needs replacing or will it now be OK as the blockage in the breather is fixed?
Opinions sought. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #437177 12th Jul 2015 7:20am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I'd check the diff oil level,refill if needed,then just keep an eye on it.
If there is no more leak,don't worry about it.
Marc
Post #437180 12th Jul 2015 7:36am
