Home > Puma (Tdci) > Bloody Defenders.
RED-DOT
Bloody Defenders.
Yesterday all was fine, today i put my rear wiper on and nothing stirs but the brake lights come on!!!! Any magicians out there had this? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #436449 8th Jul 2015 12:17am
munch90
wiring inside the rubber tube between body and rear door
Post #436452 8th Jul 2015 6:38am
RED-DOT
Thanks Munch, i will look at that tonight. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #436461 8th Jul 2015 9:03am
RED-DOT
Removed door card on rear and O/S quarter panel and wiring seems brand new.. High level brake light is not illuminating but rear lenses go out when this bulb is removed... I'm stumped!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #436597 8th Jul 2015 9:09pm
munch90
Did you check the wiring inside the rubber joining boot , you would need to pull the wires through the rubber to check wires inside the rubber joint
doudt the problem would be in the door or in the small rear panel
Post #436599 8th Jul 2015 9:13pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
I assume the fuse is ok
Post #436601 8th Jul 2015 9:21pm
munch90
Sounds like a short between the wiper wire and wire to high level brake
as your switching on wiper the wires are touching and feeding brake lights via the high level brake light wire
Post #436604 8th Jul 2015 9:27pm
I second this, or again an earth.
Causes all sorts of weird things.
The earth strap bolt is on the transfer box underneath for the rear lighting.
If you I.D. the earth for the rear wiper. (Wiper end) try adding a temp earth from there to chassis ground and see what happens.
You may find it springs into life no problem and no brake lights either.
If it does then there is an earthing issue, one that needs sorting but your temp earth may cure it for a quick fix for now.
If it's not earth related then my bet would be the rubber boot as suggested.
Also check the plug to switch too is a tight fit and not loose.
Post #436611 8th Jul 2015 9:50pm
RED-DOT
All wires are as new.... Here is what is present.
No rear wiper
Low level brake lights come on
No high level brake light although bulb is OK
Remove this bulb and low level goes off
Wires inside rubber boot OK 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #436616 8th Jul 2015 10:07pm
JWL
The earth on the heater element?
Post #436617 8th Jul 2015 10:08pm
