Home > Technical > Alarm / battery
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Alarm / battery
I've had the alarm go off a couple of times now on my Td5, completely randomly - mainly late at night!
Question is.... I put a battery charger in today to see if the battery was low, and it was - down to about 1/3 on the meter, would this make the alarm go off due to low power?
I don't do many miles and its not had a good run for a while. It only started going off after I'd fitted a Landreiziger upgraded wiring loom for the headlights, this is probably a complete coincidence, I'm just back tracking to find the cause, I can't see it being anything to do with the loom as the alarm isn't looking at the headlight loom.
Post #436289 7th Jul 2015 11:32am
rallysteve
Do you have the interior ultrasonic sensor (above drivers side b pillar or by rear view mirror)?
Might sound stupid but make sure you have no coins or metal objects (keys, spanners etc) exposed nor anything plugged into the cigarette lighter within the range of the sensor.
Most likely it is moisture caused the ultrasonic sensor to rust. Simply pull it free of the roof lining and unplug it, it can then be pushed back to fill the hole. Should stop triggering for now until you can source a replacement.
Post #436294 7th Jul 2015 11:53am
Lambley
Thanks Steve,
I do have the sensor behind my right ear, but I unplugged it after the first time it went off, so last nights events were without the sensor. It did look ok and not damaged or rusty though. There's nothing plugged into the ciggy lighter at the moment.
It just seems strange that it's gone off totally randomly.
Post #436301 7th Jul 2015 12:20pm
If you want a replacement sensor, get in touch with Kevin at MUD UK, he has a bag full, won't be expensive!!!
Post #436302 7th Jul 2015 12:25pm
If the vehicle battery voltage drops low enough the BBUS will sound, but not the vehicle horn (same as if the battery was disconnected. I doubt when the alarm was sounding you noticed whether just the BBUS on its own, or both the BBUS and the horns were sounding, but when it next happens see if you can determine this.
If it is a sensor (or other) problem causing the alarm to active, they'll all sound. If it is low battery voltage, just the BBUS wil sound.
If you have access to a diagnostic tool (eg Nanocom) the AS10 unit should have logged the trigger event, unless it was low battery voltage in which case the BBUS will just have done its own thing autonomously.
(I am assuming that you have a BBUS, of course).
Post #436313 7th Jul 2015 12:51pm
Lambley
Thanks for the replies - but what's a BBUS? Embarassed
The horn was sounding in a constant tone until I pressed the blipper
Post #436319 7th Jul 2015 1:25pm
K9F
Battery Back Up Sounder. An additional little plug and play item that protects against battery cables being cut.
http://www.defender2.net/forum/topic35612.html?highlight=bbus If you go through life with your head in the sand....all people will see is an ar5e!!
Post #436349 7th Jul 2015 4:28pm
Dora
Has it been raining where you are lately? I had a similar thing some years back. The alarm kept going off randomly and the only common thing was it was always wet when it happened. Finally traced it to water getting across a door switch fooling it into thinking the door had been opened! New switch, job done, but frustrating in the mean time!!
Post #436382 7th Jul 2015 7:11pm
Clive
Could be a faulty or mis-aligned bonnet switch.
Post #436383 7th Jul 2015 7:13pm
Lambley
It was certainly windy and showery last night, the previous time (now I come to think about it) - I'd jet washed it earlier that day Whistle All over, even cleaned the engine bay (eek) maybe some water has got in somewhere and it's still not dry yet. I don't use much pressure when washing, I just got carried away.
I've ordered a set of door switches just in case though Thumbs Up
The bonnet switch is new, the old one gave up and stayed down constantly so it was replaced a few months ago but I'll check that too. Thinking about it now though - I might check the bonnet switch position as my vehicles a Td5 but I've had a Puma bonnet fitted ages ago.
Post #436404 7th Jul 2015 8:46pm
If it's a faulty switch causing this a Nanocom would let you find out which one - the AS10 should log the trigger events.
Post #436421 7th Jul 2015 9:52pm
Lambley
Yes, I'd like a diagnostic tool, I've put a wanted ad in 'for sale/wanted' Thumbs Up
Post #436423 7th Jul 2015 9:59pm
