Home > Maintenance & Modifications > Drivers Window packed up......
J8GHX
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Hello all,
In typical fashion, warm weather arrives, drivers electric window packs up!
I've checked the fuse, all ok.
I swapped the switch with the passenger window, all ok.
I've taken the drivers door card off, and can faintly hear the motor 'click' when the button is pressed.
Window is not jammed, what should I try next?
Thanks in advance,
John
PS. 2008 90 tdci XS Currently....... all gone...... pending delivery of a mid life crisis.......
Previously..... Quite a few! I really am a sucker for them!
Post #435911 5th Jul 2015 1:52pm
Check and trace wires, especially around the area where the rubber joint goes between the door and body.
They sometimes break / degrade.
Post #435916 5th Jul 2015 2:48pm
landy andy
That will be the wires in the rubber trunking going from post to door. Very common, pull boot out both ends and inspect the two thick wires, and give them a pull. You may even find window works at certain door open positions.
Post #435920 5th Jul 2015 3:15pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Mine did this, I just cut out the wires that had gone brittle and spliced in some new, if you do go down this route then make sure you leave a bit of extra cable (just a few inches) more than it was originally, it just helps it not to pull too much when the door is fully open
Post #435923 5th Jul 2015 3:19pm
Stiff1
Did this last weekend. Drivers window would only open/ close with door at certain angle, found white wire in rubber between door and post in two. Spliced new section in and all is well.
Had a similar problem when I bought it with central locking in rear drivers side door not working. Found to be broken wire in rubber tubing.
Defenders!!! Whistle
Post #436024 6th Jul 2015 12:03am
