![]() | Home > Off Topic > Question for any builders/roofers out there |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1455 ![]() ![]() ![]() |
Its bracing just to stop the joist twisting/bowimg. Yes you can remove and place underneath, if you like, but equally boarding above will do the same job.
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2678 ![]() ![]() ![]() |
Yeah - I removed my bracing bars, and replaced them with 22mm tonged-& grooved flooring, well-screwed down to each joist. No problems yet (and I have a lot of weight up there) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 ![]() ![]() ![]() |
Cheers gents
