Home > Maintenance & Modifications > Brake Light Lens help?
timtom1
United Kingdom 2001 Defender 90 Td5 CSW Alveston Red
Hi all
I have a Red Lens for my rear brake light that I need to replace.
I've taken the light out but I can't get the Red Lens away from the black backing is it glued in place or does it snap off or unscrew a certain way??
Thanks
Tim 2001 90 TD5 CSW Alveston Red Manual
Post #434360 28th Jun 2015 8:37pm
Dave-H
The lens only isn't replaceable on your model, you'll need the complete lamp unit, only a few quid.
Earlier 90/110 had a removeable lens, later models don't.
HTH Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #434376 28th Jun 2015 9:09pm
timtom1
d'oh ok thank you Thumbs Up 2001 90 TD5 CSW Alveston Red Manual
Post #434384 28th Jun 2015 9:34pm
Clive
I've just ordered a new pair for my 90, as the old ones have gone very dull and cloudy looking due to UV exposure -
http://www.ebay.co.uk/itm/130750238464?_tr...EBIDX%3AIT
Thumbs Up
Post #434388 28th Jun 2015 9:51pm
timtom1
yeah mine have gone the same which is why I want to change them, thank you Smile 2001 90 TD5 CSW Alveston Red Manual
Post #434426 28th Jun 2015 11:15pm
Martin
Site Admin
Avoid the really cheap pattern lamps, hunt out OEM (Perei) replacements.
The cheap ones are about £3 each, the OEM £7.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #434487 29th Jun 2015 9:03am
Happyoldgit
A bit of mild abrasive such as T Cut, Farecla G3, toothpaste, Brasso etc and a bit of elbow grease will usually restore dulled plastic. Steve.
http://forums.lr4x4.com
Post #434578 29th Jun 2015 3:37pm
Clive
^ Agreed^ - in general and certainly worth a try, trouble is though, red coloured plastic often becomes "sun bleached" with age and exposure, so while you may restore the surface finish, the colour will very likely still remain faded, even pink in appearance.
Anyway, my new cheapo ones arrived this morning and are fitted, they look a lot better than the old ones and fit properly Thumbs Up
Post #434584 29th Jun 2015 4:00pm
RED-DOT
Or upgrade to LED for very little money? Plug n play... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #434633 29th Jun 2015 7:22pm
timtom1
Thanks, I have the White LED light inside it just wanted to replace the lens cover as its 12 years old and really dull 2001 90 TD5 CSW Alveston Red Manual
Post #434812 30th Jun 2015 12:36pm
If you've got an LED fixture inside it then it's illegal.
Post #434834 30th Jun 2015 2:52pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
HTH Thumbs Up
I made this mistake on my 300tdi when I assumed it would be the same as the 200tdi I used to own. Luckily I managed to replace the broken and faded lenses with the wrong ones I had ordered by carefully separating the bonded parts. It can be done and is a workaround if, like me, you have ordered the wrong parts Rolling Eyes
Post #434843 30th Jun 2015 4:02pm
timtom1
Its this bulb
http://www.outbound4x4.co.uk/shop/exterior...ight-bulbs
I was under the impression the Xeon lights were illegal..? 2001 90 TD5 CSW Alveston Red Manual
Post #434852 30th Jun 2015 5:09pm
Yes, they are too.
LED bulbs in an incandescent holder is illegal as they are designed and certified 'E' marked for use with a regular incandescent bulb.
If you want LED they need to be 'E' marked units such as the RDX or Wipac's as they are 'E' marked and tested as complete LED units.
The only lights you'd get away with this on is the reverse light as the aren't obligatory / compulsory lighting.
Post #434862 30th Jun 2015 6:09pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
If this is the current legislation, then reversing lights on vehicles after Oct '85 still have to have an approval mark - if fitted.
http://www.legislation.gov.uk/uksi/1989/1796/schedule/14/made
(A quick scan of the 91, 94 and 2005 Amendment regs doesn't show any changes to reversing lamp rules) but no guarantees I haven't missed something somewhere.
Post #434873 30th Jun 2015 6:43pm
