Home > Wheels & Tyres > ZU's / Mach 5's / Terrafirma's
Page 1 of 4 1234>
BigRuss
People I'm at a cross roads......
I taking off my boost alloys with the factory standard General Grabbers (Prob keep them as a second set), I want to replace them with a set of one of the above formentioned wheel in black and can't make my mined up.
The other thing I need to decide is whether to go for a 255 a 265 or a 285 BF Goodrich KM2 wrap.
Now I know if I wanted to go for a 285 and the terrafirma's I'll need the beadlock ring but with the others I think I can get 16"x8" wheel so don't need the beadlock.
Do I really need beadlock's? Initially I'll only be going to Morocco next year but yeah you never know maybe the Croisiere Blanche the year after.
So I need to by the right wheels at the start.
Any useful tips to help me decide please.
Post #37862 10th Aug 2010 8:38pm
discocuzzy
You dont need beadlockers, a defender with 285s at 15psi will go everywhere you will ever need to in the sand Thumbs Up You cannot teach stupid people to do clever things
Post #37876 10th Aug 2010 11:13pm
ibexman
silverline black sport bfg 255/85x16 mud awesome
Post #37878 10th Aug 2010 11:39pm
discocuzzy wrote:
You don't need bead-lockers, a defender with 285s at 15psi will go everywhere you will ever need to in the sand Thumbs Up
Don't listen to the Dell Boy Whistle He wants Bead Lockers really Wink
Each of those are great in there own way me I love the terrafirma with BL's but modulars going on for the Winter because of the road salt weird I know I'm not worried about marks from lanes / shoots but corrosion on the nuts will drive me crazy
Post #37886 11th Aug 2010 6:25am
BigRuss
Rolling with laughter Rolling with laughter Rolling with laughter
Post #37888 11th Aug 2010 7:18am
K9F
Think Mach 5 may be off your list possibly!
You don't need to necessarily stick with a 16 X 8 size wheel...With careful consideration of wheel/tyre size and offset you can achieve almost anything and change the look quite considerably. For example I run on 15 X 10 with a tyre flotation size of 32 X 11.5 which gave me almost the same rolling radius as original. My offset at 40mm is quite large but I like the 'Tonka Toy look.' It's all down to personal choice, but with a little calculation and imagination????
Matt Lee who was the original manufacturer of Mach 5s has only just gone back into production and I believe initially he will only be manufacturing beadlockers with the new flared spoke styling (IF you can get them?).
Here:
http://www.mjloffroad.com/pages.php?pid=14
The new design for 2009 bit didn't get off the ground with regards to full scale production.
Another thread I started sometime ago about Mach 5s here:
http://www.defender2.net/forum/topic2610.html?highlight=mach
Beadlockers aren't really required unless you are going 'serious off-road' and can be notoriously difficult to balance (Sonic gave up in the end on a set of beadlockers due to balancing issues - see thread above).
With Mach 5s which I hasten to add was my choice, availability is the key....I may be wrong but I doubt if you will be able to source a complete brand new set. I had to purchase three black and one stainless and get the stainless powder coated at the same place as the other three in the particular size and offset I researched as I really wanted to retain original rolling radius. At that time due to the harsh Winter I think I also could not get BF Goodrich KM2s in the size I wanted they were on a 6 week back order, quite often you may not be able to get what you decide upon so remain flexible and check availability before finally deciding to avoid disappointment.
Mach 5s come in different sizes and offsets with ZUs the sizes and offsets are very limited in comparison. It depends on what look and style you wish to achieve and whether you want steel or alloy as Mach 5s are steel. Happy hunting and don't forget to post your end result.
Buy some decent nuts and corrosion will be a thing of history.....Not cheap! I did! And it is a thing of history!
10" width 15" diameter......
About £320 per corner complete....same look can be achieved with modulars at about £180 per corner....
Hope this helps....Mach 5 everytime for me!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #37889 11th Aug 2010 7:53am
Sonics just a Wimp if you have the time and Patience you can balance to within 5g (Standard Car) but its something a normal tyre shop will wince at I'm sure Andy @ AJS would have had experience in them but understandably don't expect to pay the standard balance rate mucho beer tokens required & deserved Thumbs Up
Post #37891 11th Aug 2010 7:59am
jst
whats the legality of beadlocks for on road use?
you wont need beadlocks for Maroc or CB. i am not entirely sure why you would want beadlocks for a road goign vehicle anyway to be honest - less bling factor - and yes they do look good. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #37895 11th Aug 2010 10:18am
BigRuss
Well I'm not worried about balancing the wheels, but if your taking your wheels off for the winter Ken. What are you putting on instead??
I plan on keeping the boost alloys possibly wrap them with some different rubber but I want the muds on over winter. It was great up in scotland this year and we've already had predictions of snow next month.
With all this in mind I think I'm gonna toss the terrafirmas to the way side (but I do like them) and look at the ZU and Mach 5's. I've just got to consider alloy or metal (cost too), not to forget I need to decide what size rubber to use.
Cheers for all the help guys
Russell
Post #37902 11th Aug 2010 12:35pm
I'm fitting Modulars with BFG KO's on
its the BL bolts that will corrode not the wheel nuts Whistle
Oh why BL caus they bring the rim out to 8J Whistle
Post #37904 11th Aug 2010 1:21pm
K9F
If beadlockers bolts corrode as Ken says and the Mach 5s are like hen's teeth like I suspect, I think ZUs may be your only remaining option out of your choices. Devon do have some Staun Beadlockers on 'special' but I don't think they're your size specified. Alternatively get some decent boots for Winter use on your boosts and run two sets. Sure Ken'll do you a good boot price.
Question If you go through life with your head in the sand....all people will see is an ar5e!!
Post #37905 11th Aug 2010 1:54pm
BigRuss
The question is can Ken get me a good price on wheels as well????
Post #37907 11th Aug 2010 2:30pm
Fraid not Andy AJS has Defender Wheel tyre combos from time to time
Post #37908 11th Aug 2010 2:53pm
discocuzzy
I best get some 2nd wheels as well then Big Cry Big Cry Big Cry these wont last 2 minutes in salt
Post #37910 11th Aug 2010 3:11pm
K9F
Heyyy! Good looking! Blingety bling Disco! Thumbs Up Apologies if I spoke out of turn and was being presumptuous on boot prices Ken! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #37911 11th Aug 2010 3:27pm
Page 1 of 4 1234>
