Home > Maintenance & Modifications > Dinitrol over waxoyl
yorkshirelandy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Santorini Black
Just wondered if you can effectively give the chassis a dinitrol protection if it has already been waxoyled?
Has anyone done this?
Tom
Post #433417 24th Jun 2015 8:21pm
K9F
I had my Defender professionally waxoyled several years ago. I now use Dintrol extensively as a top up and when fitting new items. Thumbs Up
Purchased from here:
http://www.rejel.com/rejel-store/rust-proofing.aspx If you go through life with your head in the sand....all people will see is an ar5e!!
Post #433418 24th Jun 2015 8:35pm
df1
I originally wayoyled my chassis and retreated the entire inside and out with the dinitrol products, very happy with results.
Post #433465 24th Jun 2015 11:07pm
df1
Anywhere surface rust appears, say where a chip etc is, I first touch up with a rust primer.
Post #433466 24th Jun 2015 11:08pm
yorkshirelandy
Cool, cheers guys. Think I'll order some from rejel.
Tom[/url]
Post #433674 25th Jun 2015 9:46pm
munch90
Why not re-use waxoyl ?
then you know it will go over alright
if your defender is the one in the little pic and its 2004 it done 11yrs with waxoyl on
Post #433678 25th Jun 2015 10:03pm
Zagato
Treatments have moved on leaps and bounds since Waxoyl came on the market decades ago. It comes out lastsin tests as it doesn,t creep very well compared to others, it dries out leaving a cakey substance in very little time, it is a simple mix of wax, oil and white spirits and needs applying in a warm state, on vertical surfaces it has tendency to just slide down the side leaving a trace of white spirit and a heap of wax at the bottom, it is also not vibration proof, this is all well known and been said before on many forums etc... Better than nothing though and saved my old SAAB around flat, non abrasive areas back in the seventies.
The newer treatments such as Dinitrol, Bilt Hamber etc are solvent based so it like spraying on a waxy, oily glue and coats/seals waxoyl very well. They also last longer. Clients cars I did 4 years ago are still good Wink
Post #434869 30th Jun 2015 6:34pm
munch90
got cars here waxoyled once 16 yrs ago and still good
my old defender pick up 87 d reg still good never needed any welding etc ( sold in 93 ) that's 28 yrs with waxoyl
my 93 k reg 90 ht was as new when I sold in 07 it done once with waxoyl when new
Post #434875 30th Jun 2015 6:44pm
yorkshirelandy
waxoyl has definitely stood the test of time!!
I think i may just top it up this summer but do an internal dinitrol job.
Post #434924 30th Jun 2015 9:15pm
munch90
Main thing is how good the surface is to start with , how many bits you want or need to remove to get proper protection , how good your equipment is , and of course knowledge of the bits that need best protection like impact areas , water/mud traps etc
Post #434929 30th Jun 2015 9:25pm
Happyoldgit
Zagato wrote:
<snip> [Waxoyl] is a simple mix of wax, oil and white spirits <snip>
Hi Zag,
As you now appear to the Def2 resident rustproofing expert perhaps you can cast some light as to the difference in the solvent used in the two named products given the above. In my own humble experience both Waxoyl and Dinitrol will thin with white spirit. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #434942 30th Jun 2015 9:55pm
