Home > Maintenance & Modifications > Diff oil change
Shiltmeister
Spain 2009 Defender 110 Puma 2.4 SW Alaska White
Diff oil change
Hi folks
Changed the oil in front and rear diffs 2 week ago on my 2009 Puma. Unfortunately the drain plugs dripped ever since so I drained them again today to put sealant on the plugs this time. Anyway the 2 week old oil I drained out was very dirty already and completely black in the front diff.
Is this normal or should I be concerned? Possibly the original oil I drained was so dirty its still dirt left over from then. What do you think?
Post #432679 21st Jun 2015 9:57pm
dgardel
Italy
Yes Mate,
the oil is mixing with the CVJ grease, quite normal. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #432723 22nd Jun 2015 7:57am
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Is it a big job to stop to stop the grease leak through?
I guess over time the seal goes and it intrudes.
Post #432792 22nd Jun 2015 12:28pm
I've possibly got the same issue - whilst it may be "normal" in the sense that many have this issue, it's not how my axle was designed. The axle shaft seal must be leaking.
Post #432794 22nd Jun 2015 12:30pm
K9F
Depends on how often you want to strip it down to replace the seals to keep it how it was designed. It will not do any harm, perhaps a little leakage at your wheel centres may be evident later. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #432804 22nd Jun 2015 12:58pm
shaggydog
Its not a massive issue, it is definately one of those jobs which is about £2 of parts but £100 of labour.
There be the seal.
Thats the axle it comes off.
If your only doing the seal you can get away with just removing the hub assembly whole with the ball intact. However it will be effing heavy!
If it was me, I really wouldn't worry. I only did mine as it was off to do the swivel and it needed doing.
I wouldn't bother making a special task to do it, wait until your swivels are warn or you need to replace a swivel bearing and then do it all in one go Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #432810 22nd Jun 2015 1:29pm
Shiltmeister
Thanks all for the replies. Glad to hear its a common issue and not a serious one. I suppose I'd better add that job to the list of others for the future.
Do you think there is a perfectly working Defender somewhere out there? I wonder........
Post #432868 22nd Jun 2015 6:52pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
The swivels used to be filled with EP90 the same as the diffs before Landrover introduced all this one shot CV grease nonsense. I have flushed my swivels out with EP90 and gone back to oil as it is easier to monitor the level and check for any water ingress. It also avoids the problem of the grease mixing with the oil when the seal fails Thumbs Up
Post #432878 22nd Jun 2015 7:53pm
munch90
I always thought oil is better then grease as it gets up around top swivel better
grease was only a bodge repair to save having to replace the hub seals when they started leaking
Post #432882 22nd Jun 2015 8:04pm
jst
oon some of mine i have taken the seal out to allow the migration of oil between them, i wouldnt worry about it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #432886 22nd Jun 2015 8:13pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
I have the same problem, grease going somewhere, a part in the diff because the level was to high.
I have try to empty the swivel of the grease , not easy , did one screw of the pin holder.
On one side, nothing, on the other side a little. (3 years, 84.000km )
Try to put the one shot grease inside, forget to turn the wheel ...
So , I agree with you, the problem is that I have any level hole anymore !
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #443911 7th Aug 2015 7:11am
