Home > Td5 > Wonders will never cease |
Grease from outer hubs has more likely got in to axle oil turning it black and old looking
it will be the same as before soon |
20th Jun 2015 9:00pm |
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 |
A change of inner seals maybe then?
20th Jun 2015 9:07pm |
cobra_mark - you can put your vehicle details in your profile so we know what you have/how old it is?
Was surprised to see the difference in the colour of the oil between my diffs. The front was black whilst the rear was still golden. I was wondering whether i could put this down to the front diff doing more work than the rear or whether I should be looking for an issue. Oil level was certainly not higher in the front. |
21st Jun 2015 11:16am |
it will be the cv grease from the front hubs
a spoon full of cv grease will turn oil black and not enough to rise oil level that you would notice |
21st Jun 2015 11:21am |
Rather hoping it wasn't as not expecting that on an axle that has done under 10k miles!
Is there another way to confirm diagnosis easily? |
21st Jun 2015 11:48am |
Having a big garage session to sort out brakes, shocks etc. so will look at the seals.
As to my profile it appears to be filled in correctly so not sure why the details are not visible ? |
21st Jun 2015 7:33pm |
Have you looked at the "My Defender Profile" section
21st Jun 2015 7:37pm |
Yes all there, do you want me to get Martin to check it out?
A bit confused. |
21st Jun 2015 8:15pm |
Well it's there now!
22nd Jun 2015 12:12pm |
Great, just typed it out again and saved it must not have registered.
22nd Jun 2015 12:24pm |
