![]() | Home > Technical > Rear mudflap brackets |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
Go for stainless and they shouldn't look tired ever again
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5142
cheaper than stainless go for galvanised ones then etch prime and paint will look good for years and years For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
http://www.youtube.com/user/conwy1 |
| Culminator Member Since: 30 Apr 2013 Location: West sussex Posts: 305 |
Thanks both, will take your advice and will probably go for galvanised.
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
It is not just the material used but how it is used.
Mild steel cut, formed then galvanised is better then galvanised mild steel which is cut and formed. Stainless steel which is cut then formed is better then mild steel or items punched out of galvanised plate. Then there is the quality of the finish. Have seen items which have just been top powder coated then some have been bead blasted, pre coated and then top coated and cured. On thin sheet metal items the biggest problem is coverage/adhesion of the protective coating on sharp edges. Good quality finishes does not come cheap. Brendan |
| All times are GMT |
