Home > Off Topic > MSO - excel spreadsheet experts
Page 2 of 2 <12
Caterham
Eduardo,
I'm almost there with it now so I'll stick with what I've got but will have a look at the option you have given (thank you very much) for future use.
I do have a problem tho....the values against 00:00 hrs aren't being calculated Sad I can see why but not sure how to resolve.
I've broken down what I need into 4 values;
all Saturday and Sunday
Mon to Fri (7am - 7pm)
Mon to Fri 00hrs to 7hrs
Mon to Fri 19hrs to 23hrs
=IF(AND(OR(D4="MON",D4="TUE",D4="WED",D4="THU",D4="FRI"),AND(E4>F40/24),AND(E4<7>0/24),AND(E4<7>18/24),AND(E4<24/24)),B4,0)
once again thanks very much for your suggestion. in the short term I'd like to understand how to include values against 00:00 hrs and ideally pull the last 2 formula above into 1 formula.
thank you very much in advance.
Thumbs Up
Post #431920 18th Jun 2015 3:59pm
Eduardo
Easy one Mr. Green
Here it is complete
Gives 0 for Sat-Sun
1 for 7 to 19 Mon-Fri
2 for 0 to 7 Mon-Fri
3 for 19 to 24 Mon-Fri
Same principle of the other one
First IF check the day 0 for Sat-Sun and 1 for the rest
The second is an annidated IF
first IF ask if the hour is between 7 and 19 if so is 1, if not
second if check if the hour between 0 and 7 if so, 2 if not is 3
When you multiply both IF the formula gives you 0,1,2 or 3
Cheers again
Cheers! Eduardo
Post #431928 18th Jun 2015 4:44pm
Eduardo wrote:
Sorry but PhP make strange things when I put the formula in the post
It may well be mistaking your text strings as an SQL injection attack on the forum. This tends to happen with anything that vaguely resembles SQL.
Post #431945 18th Jun 2015 5:32pm
Caterham
Thud
.....I think I should have stuck to delivering newspapers !
right I'm gonna give it another go Thumbs Up
thank you - will see how I get on.
Post #431955 18th Jun 2015 6:18pm
Caterham
here's goes - another one for the experts......
I've got quite a large excel document with approx. 30 tabs each with a photograph. I'm trying to print the excel to pdf and unfortunately although I'm asking it to print the 'entire worksheet' it's simply pdf'ing one page at a time and it's asking for a file name for each tab !!! ?
I want it to simply produce one pdf file with all of the tabs/pages.
any help much appreciated.
Post #680520 21st Jan 2018 8:31pm
Page 2 of 2 <12
