![]() | Home > Puma (Tdci) > New old topic? Axles Def. 130 |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
the rear diff should be a P38 type 4-pin, so not too bad. If you search in the forum youŽll find somewhere the workshop info and I believe I read there is a HD diff type (still rover type).
steering. sounds like wheel balance. Check the propshaft is ok anyway. There are many threads about the PAS, and dont think it is your problema slds MK Puma 110" SW ............................................................. Earth first. Other planets later |
