Home > Maintenance & Modifications > Help with removing XS front set covers
miket
Hi
I'm trying to fit a new heated seat pad to one of my front seats (old one ceased to function over winter and I've found that I've missed it when it's cold!). All the videos say that the seat cover should just peel back, but when I try to do this the front of the cover seems to be fastened into two horizontal wires on both sides.
I could try to push the new heated pad up without removing the cover, but the space is very restricted and it'll be hard to get it stuck down correctly.
Can anyone help?
Mike
Post #429269 7th Jun 2015 5:26pm
K9F
'Go Beyond' may be able to advise as he retrims seats. Drop him a 'pm' perhaps? Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #429271 7th Jun 2015 5:29pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Do you mean the backrest? I tried to do mine about a year ago. The cover is fastened on with 'hog rings' i didn't actually take mine all the way off but there's a load of them going up the backrest. 1953 80"
1987 mini city e
2011 90"
Post #429283 7th Jun 2015 6:41pm
miket
Thanks Mr_James - must be the hog rings. Might see if I can snip them off without a special tool and might consider replacing them with cable ties...
A job for next weekend.
Mike
Post #429293 7th Jun 2015 7:06pm
Clive
Exmoor trim do quite a good "how to" video covering seat re-trim -
http://www.exmoortrim.co.uk/re-trim-a-defender-seat-pt-1.html
Post #429300 7th Jun 2015 7:37pm
miket
Thanks Clive - I had seen this and the cover just pulls up and off, which mine certainly doesn't do. All down to hog ties...
Post #429327 7th Jun 2015 8:49pm
