Home > Puma (Tdci) > Clutch "Death rattle"
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Well, it had to happen... Major knocking and rattling from the clutch today.. Big Cry Big Cry Big Cry
New clutch kit ordered, along with a new release bearing and transmission jack.. Thumbs Up
Does anyone have any good tips for a competant DIY'er for changing the clutch?
Anything I need to be aware of before I start unbolting bits?
Wish me luck!!!! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #428119 2nd Jun 2015 6:47pm
Shax
Wish me luck for Saturday.. The bits have arrived.. Time to get underneath and get mucky!!!!!! Very Happy Very Happy Very Happy Very Happy ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #430311 11th Jun 2015 9:57pm
Caterham
good luck.......
does kit include spigot bearing and are you looking to replace extension shaft at the same time - at least have a look while you're at if I were you.
hope all goes well Saturday.
Post #430321 11th Jun 2015 10:21pm
Shax
No spigot bearing in the kit... Big Cry
I'll order one tomorrow for Sat delivery! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #430328 11th Jun 2015 10:37pm
Shax
ARGHHHH.... Fekking cat nuts have siezed on the studs... Can't get the 'zorst off! And manual says 10 bell housing bolts, but I can barely feel 7!
Any hints tips or suggestions?? Big Cry Big Cry Big Cry Big Cry Big Cry ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #430736 13th Jun 2015 8:14pm
munch90
Most bolts go in back to front , but there are a few ( never counted !) That go front to back
hope that makes sense !
Post #430739 13th Jun 2015 8:18pm
Shax
So, the top three are front to back, unlike the others? Would make sense... Will have a mooch again tomorrow...
Prob hidden behind the fekkin cat that I cant get off!! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #430740 13th Jun 2015 8:24pm
ickle
Top three are back to front, drop rear gearbox mounts off, cross member off & lower gearbox on a jack then use a very long, extension bar and socket from the plate under the cubby, with the gearsticks out of the way you can almost see them!!
Good luck - again
Post #430744 13th Jun 2015 8:37pm
munch90
Front to back bolts are on the side , top and bottom bolts are back to front
Post #430745 13th Jun 2015 8:48pm
ickle
As for the cat nuts, a small sharp drill and carefully split them off, probably easier that replacing broken studs.
The one I couldn't shift is the 6mm one on the manifold holding the brace bar,
Post #430746 13th Jun 2015 9:08pm
I left the exhaust in place when I last changed the clutch on my 110. It's a bit more fiddly and you can't drop the main gearbox, but if you roll the gearbox back on a transmission jack there is enough room.
Bellhousing fasteners are somewhat inaccessible, some can be reached from above, some from below.
Post #430771 13th Jun 2015 11:00pm
Shax
Cheers to all who've given me some advice and guidance...
I'll give it another crack next weekend! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #430778 13th Jun 2015 11:20pm
Shax
Well, all is going to plan.. Or just about! Managed about 5 hours today..
The stuck and rounded cat nuts are off.. Irwin nut removers.. Marvellous devices.. Not cheap, but you can really get a grip on yer round nuts!
Most of the minor dismantling done in prep for taking transfer box off and then the gearbox.. Managed to locate 8 of the 10 bolts.. Hopefully, I'll find the other two tomorrow!
Oil drained from TB and GB.. Props off, zorst n cat off, crossmember off, interior tunnel and panel stripped.. Gear and hi-lo selector removed.. Jeez, the list is almost endless!
But I want to have a good mooch at the TB and GB for any wear, so taking the car to bits is a worthwhile exercise.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #432443 20th Jun 2015 9:33pm
ickle
The very best of British to you sir!
Post #432444 20th Jun 2015 9:36pm
munch90
Dont forget gearbox doesnt fill to overflow when you refill !
Post #432446 20th Jun 2015 9:38pm
