RF3777
TD5 throttle response issue? | |
Since I looking much into the lost of power issue, I started to look at different side to figure out what happened!
I'm now thinking could it be the throttle potentiometer fail!
when the TD5 running on flat road, if I floor down the gas pedal, the car doesn't response no rev up, but once I released the pedal and press slowly, the engine rev up!
I try many time floor down the gas and no response, engine only rev up if I gas down slowly...so it happened lost of power when going up hill, specially going from 2nd to 3rd gear, I floor down gas immediately to prevent the car slow down, but it usually end up no engine rev, and speed drop...mostly need to gear down to 2nd again to keep the car going!
But no warning light on dash, may be only light up if the TP sensor totally fail?
2nd Jun 2015 4:35am |
