Home > Technical > times to change clutch and flywheel TD5 90 and cost?
Landydefender1
United Kingdom 2003 Defender 90 Td5 HT Rioja Red
I have had a look in the search section however being a man I can't find the answer! What I mean is my good lady always says 'have you really looked hard enough'....... Honestly I have?
So took my 90 for a service and the garage said that in a few months I will be needing a new clutch and whilst they are there may as well do the flywheel. He said that the floors need to come out and it's a long long job.
Before I go spend my very hard earned cash does any body know how long the job should take and an average price?
I have found the clutch and flywheel kit on fleebay for £387.95.........
Any advise would be really appreciated!
Post #427354 30th May 2015 11:35pm
Lorryman100
Not sure about the TD5 but I just got my Puma done in about 6 hours for £661 and some change, new AP HD clutch, slave cylinder and single mass flywheel including labour all whilst away in the tin tent using an independent. Thumbs Up
Post #427355 30th May 2015 11:43pm
Landydefender1
Wonder if that's the same time ... Price as a TD5? They can't be that different?......... Can they?
Post #427379 31st May 2015 8:15am
barbel jim
They work roughly on 10 hours labour I had a recent price of genuine £1480 and £1060 for a Valeo.
Post #427391 31st May 2015 8:58am
Landydefender1
Is the TD5 that different from a Puma?
Post #427397 31st May 2015 9:18am
barbel jim
Pass never been near a puma yet ? The time is stripping everything out ,just to drop the box.You can get a valeo clutch,DMF and bearings for around £400. Genuine DMF is about £560 on its own !!!! Some take the engine out, others move it forward, others drop the box. Make sure you replace the spigot bearing at the same time.
Post #427417 31st May 2015 9:55am
Fatboy Slim
Wales
They're having a laugh. Td5 clutch and flywheel is a doddle to do. I used to do them in 3 hours on my own on the floor. Confident I could do one on the floor in 5 hours these days no probs.
Post #427482 31st May 2015 1:25pm
barbel jim
might be worth a trip to yours then Thumbs Up
Post #427492 31st May 2015 2:04pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I looked into it about 3 months ago when mine was slipping, I managed to sort it but the local garage quoted me approx 10 hours labour plus the cost of the clutch. They asked L/R about replacing it with a solid flywheel too, which I asked them to, but they said the local L/R dealer had not recommended doing this as it ended up being very noisy to the point of people returning to the dealers asking what's wrong, so stick with the dual mass.
I think it came to around £850 ish, plus there might be some seals, oils etc. They recommended Valeo parts
Post #427495 31st May 2015 2:54pm
Landydefender1
Where in the UK are you? Will you do mine?
Post #427660 31st May 2015 11:50pm
