Home > Technical > 90 Tdci 2.4 'surging' on overrun
SimonDavies
Wales 2010 Defender 90 Puma 2.4 HT Zambezi Silver
Hi,
My father has got a 59 plate 2.4 tdci 90. He is complaining that when approaching junctions, roundabouts etc, taking his foot off the throttle and vehicle goes into overrun, a surging occurs as the engine revs drop. The vehicle itself will jerk back and forth until it almost comes to a standstill. When the surging is happening you can see the rev counter bouncing up and down, but only very slightly.
So far, the engine has had two faulty injectors replaced and also an EGR valve. However the fault was there prior.
No engine management light on and no stored codes.
Has anyone come across this fault, or have any ideas as to what may be the cause.
Thanks,
Simon
Post #424684 19th May 2015 7:05am
SimonDavies
Does anyone have any ideas where to go on this one?
Post #427579 31st May 2015 6:37pm
Caterham
no is the honest answer but just wondering.
do you think there's any chance this could be a mechanical problem (running gear / gearbox) rather than the engine?
Post #427608 31st May 2015 7:32pm
SimonDavies
Honestly, we are still trying to work that out ourselves. My father thinks engine but I lean towards mechanical.
Its very difficult to put the fault in to words.
I thought it may be a bind on the handbrake, but that would always have an effect I would have thought.
Post #427626 31st May 2015 8:32pm
Caterham
I know what you mean.
contrary to what everyone on here thinks I believe I'm reasonably ok with mechanics......
that said after 4 years of thinking I had an intermittent engine issue / electrical problem I'm hopefully going to find out later this week it was the clutch (can't wait).
bearing in mind how long it's taken me to realise it might actually be the clutch (to be fair there's be enough of other problems to send me off in the wrong direction) I certainly wouldn't rule the clutch out......
are there any other 'issues' that might be clutch related ie switching engine off with or without the clutch depressed - does it behave differently?
is take up always smooth
how does it sound on tick over with / without the clutch depressed?
good luck. Thumbs Up
Post #427633 31st May 2015 8:49pm
I know it sounds daft, but check the brake light fuse. If it has blown it can cause wierd effects on the ECU.
Post #427643 31st May 2015 9:33pm
SimonDavies
Caterham: he has never mentioned any clutch related issues but I will check with him tomorrow. I know that they are a common fault of the puma. I think his 90 is on around 50k, original clutch.
Blackwolf: that is not something I would have thought of so will definitely mention that to him, thanks.
Post #427653 31st May 2015 10:26pm
