Home > Technical > Heated windscreen
Screbble
Heated windscreen
Hi all,
My factory fitted heated windscreen is in need of replacement as it has quite a large chip/crack in it and the rubber has seen better days. It still works though!
I've seen quite a few for sale on Fleabay at a decent price (supply only) but I was wondering how easy and expensive it would be to get it fitted? Anyone know any recommended fitters in the Merseyside/Lancs area?
Obviously I could pay the excess on my insurance and get it replaced via the well-known mobile company but I'm not sure if that would be any better than the above.
Clearly there's no right or wrong approach here, however I'm interested in your advice/opinion.
I don't want anything doing for nothing or on the cheap but I do want a decent job doing.
I think it'll be fine for a few months but I doubt it'd get through the MOT.
Thanks in advance,
Will
Post #424054 16th May 2015 8:29pm
Al_The_Pal
2015 Defender 110 Puma 2.2 XS CSW Corris Grey
I broke mine last weekend changing the rubber, thought I knew what I was doing, I've done all the glass in my VWs before and not had a problem.
Wish I'd have got the windscreen man in to do it as I was advised when I said I'd do the defender myself Smile
I'm paying the excess but have to wait 4 weeks for them to get a top tint screen ordered.
Post #424061 16th May 2015 8:55pm
Litch
Why would you NOT use your windscreen insurance?
The windscreen excess is usually only around £50 and it has no effect whatsoever on your NCD, also it is completely hassle-free.
I have had my heated screens replaced several times now and always use my cover, silly not to. Mind you, I always make sure I have a new rubber to hand before calling them. ONE LIFE, GET IT!
Post #424062 16th May 2015 8:59pm
Al_The_Pal
Could have got the local non chain widescreen guy to re-fit for £40 BTW
Post #424063 16th May 2015 8:59pm
YOLO110
Australia
... Are you that hard up!!! Laughing YOLO... You Only Live Once...
Post #424119 17th May 2015 9:30am
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
According to my local windscreen man, flat screens are far less forgiving than curved screens.
Post #424140 17th May 2015 12:19pm
K9F
^^ He is damn right speaking from personal experience and the fact I am on my third one in 6 years. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #424183 17th May 2015 4:24pm
SteveK
My heated screen has a few broken elements and a chip. Just looked at my policy and the repair excess is a tenner, but replacement carries an excess of £140 ouch!!!
Post #424193 17th May 2015 4:52pm
RobKeay
Nfu £60 came straight away and fitted it and even used sealer and no leaks.
Post #424203 17th May 2015 5:16pm
Litch
That is why you need to check insurance policy details on renewal, things like windscreen cover can make what initially look like a good deal so much more expensive in the long run. With my policy repairs are free and replacement is £50.
The last two screens I had replaced were due to broken elements. ONE LIFE, GET IT!
Post #424852 19th May 2015 7:37pm
Screbble
Great replies folks. Thanks.
I agree that this has highlighted the need to critically review insurance policies as much as anything!
At this stage I'm airing on the side of getting 'the approved man' to do it via the insurance (excess) and I may even have a spare rubber to hand, although not for the reason suggested...........
I suppose it does then bring me back to one of the original questions - why would you not have it done via the insurance? Noting that if your excess is significant that may be the reason.
Some folks are clearly buying the screens and getting them installed themselves - I wonder why? (Rhetorical).
This morning we enjoyed heavy, driving rain. Despite the state of the rubber, and the extent of the damage ,the screen didn't leak and the heater did its stuff. Maybe I'll leave it after all!!! Only kidding!
PS the rest of the Landy leaked, just not the screen! Thanks folks.
Post #424939 19th May 2015 10:44pm
Brucey
Poland 2004 Defender 110 Td5 DCPU Auto Java Black
I have the same heated screen as was factory installed, so 11 years old. I only get a strip that works both sides but the glass is fine with no cracks or chips.
How do the elements fail if they are embedded into the glass? Is there some abrasion of the element somewhere that can be repaired?
The e-bay suppliers? how likely that they can deliver to Poland without delivering a broken screen?
Thanks
Chris Defender 110 DC converted Auto
BMW R1200GS
BMW F650GS Dakar
Post #425012 20th May 2015 9:01am
K9F
The element is laminated into the glass so no repair is possible. It is also very fine so even a slight impact can break it without damaging the glass. You could get a multimeter and on the lower corners of the glass each side there are terminals you can check. There are in fact two heater elements in the screen and both should read the same resistance value. I am unsure what that value is. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425028 20th May 2015 10:21am
Brucey
Hmmm, seems pretty feeble to me. (the wire/design, not the answer!!) Confused
My Landy had reasonably hard use in Polish winters and the awful out-of-town unmade roads, but the only impact on the screen that I am aware of would be the bumps on the potholes.
I was wondering if there was some form of electric BUS bar or tape along the bottom of the screen that may have been abraded.....?
BMW R1200GS
BMW F650GS Dakar
Post #425033 20th May 2015 10:30am
K9F
Corroded perhaps? A quick inspect of the terminals I mentioned will reveal. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #425036 20th May 2015 10:32am
