![]() | Home > Puma (Tdci) > TDCi brakes dragging. |
I had it happen , but it was only because I had brake light switch out and it had got stuck when fitted back and was holding the pedal down a bit , pulled pedal up , loud click and all fine , checked lights working ok
other than that could be problem with master cylinder flexi rubber brake hose seized calipers pads seized in calipers its worth getting it checked professionally being a brake problem |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031 ![]() ![]() ![]() |
The only time mine dragged was due to a stuck piston in one caliper.
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Check the vent in the master cylinder is not blocked? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
ozy013 Member Since: 10 Feb 2014 Location: Melbourne Posts: 105 ![]() ![]() ![]() |
"So they've fixed the issue. Apparently the brake switch was out of adjustment causing it to think the brake pedal was still being pushed causing the abs pump to stay activated and the brakes to hang on if that makes sense".
Just a quick update and also thanks for your suggestions. It seems the owner took it to the dealer and they pretty much sorted it straight away. ![]() |
CarlS Member Since: 10 Apr 2007 Location: Probably near you Posts: 148 ![]() ![]() |
Ahhhh this is interesting, mine (2015 tdci) sometimes smells hot, I was thinking "is it the brakes?" but just put it down to the newness burning off.
The brakes sometimes squeek loudly when slowing down from 10 - 0mph slowly. I drove it down to the local cafe this morning and on the way home I thought I heard the ABS kick in. ![]() Think I need to look into it a bit more by the sounds, I've only done 600 mile in the truck from new. The spawn of AndrewS 2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead 2016 Mini Countryman Cooper S All 4 2019 BMW R1200 GSA Rallye Sport |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
What you need is my new infra red thermometer
Yea it is
![]() 2016 Defender 110 XS Station Wagon (Built on the last day, 59 from the end) - Dead 2016 Mini Countryman Cooper S All 4 2019 BMW R1200 GSA Rallye Sport |
PAT303 Member Since: 25 Feb 2013 Location: Australia Posts: 126 ![]() ![]() ![]() |
Hey,this is my thread,get your own ![]() |
Hey Pat, oops sorry wont do it again
![]() Ian. |
