![]() | Home > Technical > 110 Rear Axle Half Shafts |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18058
Disco axle, perhaps?
| Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 831
Not sure....I hope not.... to me the Diff looks like the 110 rover type
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 927
It would need checking of axle numbers but on first impressions that is a TUL Rear axle. Or a Army Wolf 90. Stronger diff but still one piece rear shafts.
A bit of detective work with a wire brush should reveal an axle number. |
TUM would have a P38 diff I think. Not sure about TUL.
Tks Fellas, on further investigation trawling part numbers the shafts seam to be from a early 2004 90 24 spline rear axle
I assume there is no issue running them with the rover axle and diff |
As long as the splines fit the diff (which clearly they do), no issues at all.
You won't have the pleasure of replacing the worn-out halfshafts and drive flanges every couple of years that we Puma owners do though! |
| Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006
I'm sure the one piece shafts will fit puma defenders as well
| All times are GMT |
