Home > Technical > Fluid leak coming down the inside of the passenger wheel
Landydefender1
United Kingdom 2003 Defender 90 Td5 HT Rioja Red
looked underneath tonight and found a leak off fluid that is coming down the inside of the passenger wheel?
What might be above it that would leak?
Any help or advice would be appreciated.
Post #423333 13th May 2015 9:15pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Sounds like calliper seals, or a brake line that's leaking?
Check you fluid level, and get it sorted ASAP! 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #423338 13th May 2015 9:30pm
Happyoldgit
Failing swivel seal will leak onto the inside of the tyre generally worse if it's an earlier model with oil filled swivels. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #423345 13th May 2015 9:54pm
Landydefender1
Leak
It's a 2003 90
Post #423376 14th May 2015 6:45am
It could also be a failed hub seal.
Post #423387 14th May 2015 7:30am
Landydefender1
Going to take it to Bob Trice Beverley East Yorkshire......... The joy of owning a Defender is now upon me....
Post #423632 14th May 2015 9:00pm
