Home > In Car Electronics > Disable bluetooth on the factory Alpine CDE-133BT unit
Tim_NZ
Australia
I've fitted a parrot tablet to my car for all my hands free calling needs, however ever since when I start the car the Alpine unit asks (twice) if it wants me to pair. Can some one tell me how I can disable the bluetooth, or stop the Alpine unit from trying to pair every time it is activated?
I have tried with the "HPF" setting both on and off.
Thanks in advance,
Tim
Post #421760 7th May 2015 10:46am
K9F
You could just carry out the latest firmware update apparently that can disable the bluetooth function anyway if it was an OEM fit in the Defender.
http://www.alpine.co.uk/support/bluetooth-...oup-2.html
Have you looked thoroughly through their support link or tried contacting and asking them direct?
http://www.alpine.co.uk/support.html
e-mail... support@alpine.co.uk If you go through life with your head in the sand....all people will see is an ar5e!!
Post #421768 7th May 2015 11:13am
Tim_NZ
Australia
Thanks K9F, I did consider the update to "break" the unit! But knowing my luck it would actually work for a change! I'll try to contact Alpine to see what they say.
Cheers,
Tim
Post #421775 7th May 2015 11:30am
K9F
No worries. I have no experience with Alpine head units but when it is trying to pair with your phone do you not get any prompt on the phone giving you options such as:
Ignore, Do not ask again or Don't Accept?
Just an idea. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #421777 7th May 2015 11:42am
Tim_NZ
Australia
OK, found the problem, it still had my phone in it's memory, even though they were no longer paired. So, everytime it started.... do you want to pair? (x2).
Post #421989 8th May 2015 12:02pm
K9F
Glad you're sorted. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #421995 8th May 2015 12:23pm
