Home > Td5 > OEM stereo single din cage? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
Just took out the stereo trying to install the new bezel, then discover all the parts are gone!
retension wires and bolts, the single din cage doesn't seems to be OEM, because it doesn't fit to the bezel... My question is can I used after market din cage to fit on the OEM bezel? if not can anyone provide me the part number of that cage? Thanks |
6th May 2015 5:30am |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 |
6th May 2015 8:28am |
OK, I just don't want to give up, took of the whole HU went home and try it out...
using that cage...and I have only one retaining wire, I didn't know the order is per one item! I installed the wire on the lower part of the bezel, I think the lower take more weight! carefully remove the whole facia, and unplug some buttons, insert the radio... I have done it! |
6th May 2015 8:53am |
I know it's a bit agricultural but when I put my head unit in mine I put a block of wood towards the back to allow the radio to rest on so it wasn't allways trying to twist the front off. Mine stays in with just the clips on the side I haven't used the wire clips at all and my Defender gets used for everything from the school run to greenlaning and going to pay and play sites and the radio never moves.
6th May 2015 9:17am |
