![]() | Home > Technical > Smokey TD5 |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
I'm a bit confused Taazz, is that exhaust gas venting from the cylinder head?
taazzukcb Member Since: 30 Aug 2013 Location: Derbyshire Posts: 663 ![]() ![]() ![]() |
It's blow-by. Often have a small amount on Diesels due to higher compression. Also you get more with high mile'ers or engines with a heavy use history resulting in worn rings (also perhaps to much idling on a diesel causing glazing etc).
Just wondering if mine's a tad excessive? Can also be caused by low compression in 1 or more cylinders. TD5's have a 'small' history of bent con rods, so just wonder whether this might be a concern to. Just wondering if the smoke is excessive mainly! 104,000 miles. |
bifterx Member Since: 29 Nov 2014 Location: North Wiltshire Posts: 33 ![]() ![]() ![]() |
Hey taaz
Wondered if you had any joy with this? My td5 is exhibiting similar symptoms - just had new cyl head cos I had a crack, and my guy said the truck had deffo had a remap in its past cos it pulls like a train. So I was looking at a Provent like you have as I can't stop the oil leaking out of the breather - but now I got this smoke on change up, so thinking maybe the combination of cracked head (diesel in the oil) and the remap - higher compression in the crankcase etc might have 'interfered' with the turbo seals. Not sure sure which way to jump. Cheers Disco 300TDi XS - Gone Disco 3 SE manual - Gone 😭 Freelander 2 SE manual Defender 110 TD5 DC |
Oh he has had joy.....taking the td5 out and putting a BIG horsepower OM606 in it
oh - thats one way I suppose. Problem solved! better do a bit of cut and paste to a new post then! Disco 300TDi XS - Gone
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
I have taaz's Td5 now, still running well, on standard turbo & power these days though....
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
Looks fine to me
