Home > Td5 > 2003 TD5 clutch noise? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 |
Looking for some info to figure out why my TD5 clutch has some squeeze noise every time I release the clutch pedal!!
sounds like "EEEEEEEEEEEEEERR" does it need lube on the spring? Thanks Update video add! https://youtu.be/31WqOclzB-Q Last edited by RF3777 on 5th May 2015 9:56am. Edited 2 times in total |
5th May 2015 4:42am |
isn't it caused by the spigot bearing , quite common thing on the td5
5th May 2015 6:40am |
Where is the spigot bearing about?
how can I fix it? Thanks |
5th May 2015 7:06am |
inside the flywheel , sorry not a simple fix
5th May 2015 7:10am |
Can I just leave it as is?
if this not a serious problem... |
5th May 2015 7:12am |
Hi, Lambley
The noise sounds more from the footwell, would try to lube the spring first! Is it possible spray some WD40 through the hole where the pedal come out? Sorry but where is clutch box located? |
5th May 2015 7:43am |
Just read first post again , noisy spring
sorry must have been to bit early for me this morning and said about spigot bearing ! |
5th May 2015 9:43pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
It looks like your pedal has had the spring modification done - which makes it easier to press the pedal, mine creaked a bit until I'd greased it, try and grease the spring at the back of the pedal, where it fits into the 2 plastic bits in either side, just put a bit of grease around there and where it touches the back of the pedal and see if it stops squeaking, if not then have a look under the bonnet - above where the pedal sits, there will be a cover with 6 screws, undo them and have a look inside - it should look like the picture posted above, just grease the moving parts of the pedal, try not to get too much grease near the rubber boot that's on the cylinder - just use a spray grease, you'll be fine.
5th May 2015 10:25pm |
I did some WD40 on it, both the pedal and the clutch box...
the clutch box rubber boot looks torn! I did some spry on the rod! |
6th May 2015 1:54am |
And did it work?
If not I'd be tempted to take the spring off the back of the pedal and replace it with an original one, you might have to buy one though, not expensive |
6th May 2015 5:36am |
The noise seems to be down alot, will take a ride later today...
since busy with the stereo bezel... |
6th May 2015 5:39am |
