Home > Td5 > Defender cutting out under load but idles fine
chinnus
2001 Defender 90 Td5 ST Coniston Green
Hi all,
Have been a having a problem with my EU2 defender that has gradually just got worse. The defender will cut out when driving (when taking foot off accelerator it cuts out). It has suddely also just started to not start - it will fire and then cut out and yellow warning lamp illuminate
To restart after this have to lock and unlock immobilser to get yellow coil on.
I have a nanocom and have the following faults...
3.8 Manifold pressure circuit (logged high)
3.7 Air flow circuit (logged high)
1.7 Air flow circuit (logged low)
10.6 MIL lamo drive open load
10.7 glowplug lamp drive open load
20.2 turbocharger overboosting
28.7 Topside switch failed pre injection
Now this is odd because I have just replaced a dead ECU and its happened again??
any ideas would be greatly appreciated
many thanks
Post #421124 4th May 2015 7:02pm
Cold_n_Wet
Norway
free up the wastegate actuator as the turbo is overboosting and car is going into limp mode.
The nanocom shows this. "Rafiki" 2007 110 STW - Rolling rebuild.
Post #421643 6th May 2015 7:22pm
ajps72
2001 Defender 110 Td5 SW Chawton White
it look like you have some electrical problems, have anyone put 12vdc on the sensors? that could kill the sensors and the ecu.
disconnect the maf and pressure sensors and the engine should work, but you have to solve the electrical problem Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #421911 8th May 2015 2:38am
MadTom
3.8 and 20.8 - check the wastegate - it can be stuck, check the small pipe connecting wastgate and turbo output - it can leak
28.7 - check or replace injector harness in the engines head
rest - check and probably clean MAF sensor internals and MAP sensor internals "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #421916 8th May 2015 6:14am
chinnus
many thanks
Dear all many thanks for all the suggestions.... I will give them all a go!! and report back...
Turbo overboost would not lead to all the other faults, would it?
I have just bought a new injector harness.
Will report back
thanks again
Post #422654 11th May 2015 3:09pm
