Home > Puma (Tdci) > Gearshift Hanging RPM
aage
Iceland 2011 Defender 110 Puma 2.4 DCPU Alpine White
Recently when shifting gears the RPM takes a few seconds to fall back to normal much longer than usual.
The strange thing is that if I�m at standstill no speed it act normally as far as I can tell. I can step on the throttle and the rpm drops back normally, so this is only when I�m driving that this happen.
Does anyone have a clue what might be wrong ?
There are no trouble codes
I did disconnect the Clutch switch ( the one connected to the clutch pump assembly and nothing changed doing that.
BTW my puma has 34.000 km on the clock and has been almost trouble free Smile
I would be thankful for any help in this matter. http://www.defender2.net/gallery/index.php?cat=13451
Post #420711 2nd May 2015 6:42pm
bobcat
Check brake light fuse and bulbs.
Post #420746 2nd May 2015 9:21pm
Caterham
Check the clutch switch on top of the master cylinder. Thumbs Up
Post #420747 2nd May 2015 9:22pm
Dieselhead
Happened with mine. Blown brake lamp fuse after towing Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #420762 2nd May 2015 10:08pm
aage
Thanks a lot guys.
I think I have already checked the clutch switch. I disconnected it and no change, then I connected btw the two poles on the switch with a wire and no change.
I�m gonna check the brake light and bulbs tomorrow morning. It might be that. I have had a water entering the rear brake lights. Yes gonna check that tomorrow morning , the brake lights and fuse. http://www.defender2.net/gallery/index.php?cat=13451
Post #420777 3rd May 2015 12:06am
Roz Dev
Ireland 2015 Defender 110 Puma 2.2 SW Keswick Green
Mines doing it too, asked the same question in the technical forum last week, here's the reply
http://www.defender2.net/forum/topic22317....ev+holding
Post #420782 3rd May 2015 2:00am
aage
Thanks again (Solved )
You where right . The brake light plug was rusted and shorted, the fuse blown. Tomorrow I�m gonna buy new brakelight plug.
Thanks a lot guys , you saved me a lot of work (I would probably never have figured this out by myself) Smile. http://www.defender2.net/gallery/index.php?cat=13451
Post #420990 4th May 2015 12:18am
YOLO110
Australia
Re: Gearshift Hanging RPM
My 2.2 has done this from new...
Don't they all do this? Shocked YOLO... You Only Live Once...
Post #421001 4th May 2015 7:03am
aage
Now drives like new :-)
New brakelight plug and fuse. Drives like brand new again Smile. http://www.defender2.net/gallery/index.php?cat=13451
Post #421136 4th May 2015 7:36pm
Cupboard
it's only a feature in the 2.2, it's a fault in the 2.4.
Post #421283 5th May 2015 12:49pm
YOLO110
Australia
Ok!
Do you happen to know why is the a 'feature'? It's actually a PITA! Laughing YOLO... You Only Live Once...
Post #421297 5th May 2015 1:25pm
