Home > Off Topic > Harvey Frost mods
Page 2 of 2 <12
excossack
That was one option I did think about that idea, but then I thought well I have all the main bits already I need so why not use them?
There is still time to change my mind. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #420418 1st May 2015 1:53pm
munch90
personally I would start with a trailer axle complete with suspension , brakes , , hubs , mounting points already on it then work up from there
Post #420425 1st May 2015 2:10pm
excossack
The axle I have purchased is complete except for the suspension. Leaf springs will get in the way / move the axle too far back. 1999 Defender TD5 110
Regards
John M0VAZ
Post #420454 1st May 2015 5:05pm
munch90
I don't mean leafs , axle with indespension style suspension
like eBay item number:
eBay Item No. 251941086728
Post #420458 1st May 2015 5:30pm
excossack
That type did come up in conversation with the man in the trailer shop. He suggested that the beam type axle would be stronger and more suited to the role I am going to be using it for. 1999 Defender TD5 110
Regards
John M0VAZ
Post #420465 1st May 2015 5:56pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Hi.
I as a side hobby I spend a little bit of time here and then around rally stages and I have seen a few dollys in use. Atlas Rally Recovery run a unit which uses indespension units and 13inch wheels. They can be found on Facebook if you have such new-fangled technology.
Down here Ralph of Western Rally Recovery again uses a similar outfit although with a spec lift instead of suspended.
Post #420499 1st May 2015 8:37pm
munch90
what you using for suspension?
Post #420513 1st May 2015 9:35pm
excossack
I am going to use the coil springs that are on the Harvey now. On the pink picture the spring turrets are the upright tubes. 1999 Defender TD5 110
Regards
John M0VAZ
Post #420524 1st May 2015 10:14pm
excossack
Devon-Rover wrote:
Hi.
I have seen one or two using indespension units but kinda like the solid beam type axles. No Facebook for me Sad
I have seen a few pics of Ralph's setup knocking around. There are many ideas/setups around the rally scene. Its case of which works best for me I guess? 1999 Defender TD5 110
Regards
John M0VAZ
Post #420525 1st May 2015 10:17pm
munch90
Ah ok , thought you wanted to get rid of the coil spring set up because of way the axle mounted
Post #420527 1st May 2015 10:21pm
excossack
No the coils are staying. Essentially its the same suspension set-up mirrored across to the wider axle and using new coil mounts on the axle. 1999 Defender TD5 110
Regards
John M0VAZ
Post #420531 1st May 2015 10:30pm
Devon-Rover
That is atlas Recovery tow dolly.
Post #420584 2nd May 2015 9:14am
excossack
Thanks - Looks a well used bit of kit. 1999 Defender TD5 110
Regards
John M0VAZ
Post #420601 2nd May 2015 10:58am
excossack
Work has started. New axle collected 45mm solid beam with 5 stud hubs and 12" wheels.
5mm folded U channel section also collected along with the spring turrets.
Old axle removed from the Harvey to make life easier measuring up - the old axle can be refitted in about 30-45mins so the Harvey can stay mobile if needed.
The U channel needed a bit of trimming down to fit between the hub back plates.
In the picture the inside of the black tape (as shown on the wood) is the original width of the Harvey axle, so it works out about 13-14" extra per side with the new axle.
Next step is to cut out two 60mm holes for the spring turrets to sit in and then I can tack weld these in place and then to fit the U channel to the existing Harvey frame so then I can work out the other bits needed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #425773 23rd May 2015 7:44pm
excossack
A bit more done today with a help from a mate.
Started to get the U channel into place to see how it fits and see how it looks with the spring uprights in place.
From the rear
From the front
Next step is to bolt the U channel to the original section to get things in place and ready for the next bits. 1999 Defender TD5 110
Regards
John M0VAZ
Post #432226 19th Jun 2015 7:28pm
Page 2 of 2 <12
