Home > In Car Electronics > I've confused meself again
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Evening folks,
It's kinda Landy related as I'm using a product more frequently used on green oval machines Very Happy
I have been fitting an second leisure battery on my mercedes camper using a X-Eng split charge, all is well so far, and just about to connect the "exciter" wire to the relay BUT !!! Here's my dilemma
I have gone from positive to positive terminals with the split charge Inbetween, But - on the earth terminal second aux battery I have taken a cable direct to a healthy earth on the body,
Is this ok Neutral
Can't see an issue from where I sit but in the diagram it shows running a cable direct from post to post on both battery's ,
Although this isn't impossible it would be very tricky due to the location of the second battery
Thanks for answering my question and sorting my frazzled brain out Laughing
Post #419991 29th Apr 2015 5:42pm
rallysteve
Thats how it should be done Thumbs Up 02' 110 TD5 Double Cab Rebuild Thread
Post #419998 29th Apr 2015 6:17pm
Daisy90
Which way ?? Confused
Post #420000 29th Apr 2015 6:21pm
rallysteve
No issue with earths both tied to the body/chassis as long as they have a good connection. Might be worth measuring the resistance between earth terminals to make sure if you arent sure.
Hth
Post #420011 29th Apr 2015 7:13pm
Daisy90
Thanks matey Thumbs Up
I'll connect the last wire tomorrow then,
Post #420055 29th Apr 2015 10:50pm
