![]() | Home > Td5 > Rear indicators - body to light seal |
eBay Item No. 261338185781
Cut your own maybe ? |
cobra_mark Member Since: 17 Feb 2015 Location: West Yorks Posts: 213 ![]() ![]() ![]() |
Can do that, just seeing if there was a precut version.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20980 ![]() ![]() |
Contact Bolt on Bits on eBay via eBay message of phone.
They could probably supply a couple to you. ![]() |
Thanks will get to it
Worth a go anyway.
What luck the foam seal is part of the Brit part replacement.
All fitted and working thankfully. ![]() |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Lucky man - a Britpart lamp that actually works?! Something that I've never managed to find! 2005 Td5 | 90 Station Wagon | Tonga Green
Well I'm truth I had to clean up the poor moulding and lump of plastic in the plug end that stopped it pushing together, lucky after a fashion.
