![]() | Home > Puma (Tdci) > over revving during gear change |
jlerra Member Since: 10 Jul 2009 Location: Gibraltar/London Posts: 149 ![]() ![]() ![]() |
Hi all,
I have a problem when changing gear, especially the low gears (1st./2nd/3rd). When the clutch is depressed to change gear and the foot is raised from the accelerator the revs continue to increase momenterally e.g. the revs don't drop instantly, it rises briefly. Seems more noticeable when the engine is cold. Any comments on experiences El pepe flamenco JLS 'El Pepe Flamenco' |
Thanks for the tip LROV90.
I shall investigate further. regards Joe El pepe flamenco JLS 'El Pepe Flamenco' |
Forest of Dean 90 Member Since: 29 Apr 2009 Location: Forest of Dean Posts: 68 ![]() ![]() ![]() |
"Often using a trailer with bad wiring"
Don't they all have Bad Wiring ![]() |
bjartin Member Since: 17 Nov 2009 Location: Hedmark, Matrand Posts: 108 ![]() ![]() |
I'm having the same problem after I installed Cruise Control. It was not something I noticed before I had installed Cruise Control. The symptoms are exactly as you describe. My workshop canīt come up with a solution, must wait for the latest software. (???). Puma 90 MY 2010 (sold 2017)
Defender 110 MY 2001 http://www.youtube.com/bjartin |
Hi all,
Have been in touch with my dealer (who are pretty good and very obliging - contrary to many general comments about dealership) who is investigating with LR about the software/master cylinder switch/brake fuse and they will give me feedback prior to taking the truck in for correction. Will keep you informed of what happens. Joe El pepe flamenco JLS 'El Pepe Flamenco' |
Hi Joe Have you received any feedback that you want to share with us! bjartin waiting anxiously. Puma 90 MY 2010 (sold 2017) Defender 110 MY 2001 http://www.youtube.com/bjartin |
Hi,
Sorry for the delay in posting the result of the problem with the 'overring when changing gear'. Thanks to LROV90 and his advice I took the vehicle to the dealer and they changed the Clutch Switch on top of the master cylinder which signals the ECU to drop the revs on gear change and the result........100% cured the problem. So, off you go to the dealer and insist on them changing the Clutch switch on top of the master cylinder and all should be fine again. Good luck Joe El pepe flamenco JLS 'El Pepe Flamenco' |
Joe, thanks for the quick reply.
Next Monday I have an appointment with the workshop and they will get a copy of your post ---- hence my problem will be history Many thanks Joe. Puma 90 MY 2010 (sold 2017) Defender 110 MY 2001 http://www.youtube.com/bjartin |
Pleasure to be of help!
Also thanks need to go to LROV90! Joe El pepe flamenco JLS 'El Pepe Flamenco' |
LROV90 Member Since: 22 Jul 2009 Location: geelong Posts: 10 ![]() ![]() |
No probs!
Now is also my 90" healed, thanks to this knowledgeable and helpful forum. ( this time read LROV90 ). Puma 90 MY 2010 (sold 2017)
Andrea Member Since: 02 Sep 2010 Location: South Africa Posts: 30 ![]() ![]() ![]() |
Hi there.
I have had the exact problem with my puma and after much searching for the problem, (the dealers say that its a clutch switch or what not that they are changing but actually it is a fuse. You will notice that it starts doing it after towing> sometimes the trailer shorts witht the car and blows a fuse. Check the fuses in the driver legwell, not under the seat, will be 100%. Good luck |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
