![]() | Home > Puma (Tdci) > Rear aux power socket for dash cam |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
If you mean the purple wire behind speaker panel [often used for aux power supply] then It's a permanent live feed, not switched. Guns and Landrovers .... anything else is irrelevant.
General Grabber Member Since: 27 Dec 2013 Location: Mos Eisley Posts: 49 ![]() |
Thanks Dave,
Yes that's the one. I've done the mod, but just couldn't remember if it was permanently live or not. |
If it is only ignition live will the camera record any parking prangs whilst you are away from the vehicle?
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8446 ![]() ![]() ![]() |
Does anyone know which fuse this supply runs off? Cheers
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 ![]() ![]() ![]() |
Hi there, 20A fuse of the towing socket under drivers seat.
cheers, is there only one 20A in there? Cheers
You could always put a little split charge relay in there to make it only come on when the engine is running.
I've been mulling over putting a small battery back there in the lights box to run lights and charge phones from. |
ok, so where is this 20A fuse, only have 15 and 30 in there. in the little box that is or is it somewhere else? Cheers
now sorted, thank you for pic HairySteve
i had confusuion over the fact that mine had a 15A fuse in there! typical LR! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
