![]() | Home > Puma (Tdci) > Heating in the footwell |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3676 ![]() ![]() ![]() |
there a couple of threads on here about this, it appears a dragging hand brake can cause it , easy to check as it would be very hot after a run, however it happens with no defects due to heat from the exhaust, mine has improved since removing the centre silencer and replacing it with a straight through pipe. Clutches generally start to fail with a rattle and there is no reports of extra heat, to create a lot of heat it would need to be slipping again there are threads on here about clutchs DEFENDER 90 TDCI XS,
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
It won't be the clutch, and heat in that area is quite normal. Benith that area you have the exhaust, and just infront the cat and turbo. I doubt you have anything to worry about, but it certainly won't be the clutch.
Andy |
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 ![]() |
Many thanks guys. Very much appreciated.
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Bet you had the window open ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Main Brian James Trailer Dealer for South West UK |
Yes I did, and had the AC on during the return trip when I didn't feel the heating in the foot well. But what has having the windows open got to do with this?
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2674 ![]() ![]() ![]() |
open window = heat sucked through the gearbox area into the cabin.
that is why the original Defender had those windscreen flaps - with these open, it would create a high pressure zone in the cabin and the cabin would stay cool. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Naks beat me to it,, an open window suck's the heat up from the seat box, had the same on all past Puma's California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Tks TJ. Glad to know there is nothing technically wrong.
![]() Probably should be starting a new thread but how do I know it is time for a new clutch. Presently I get a clunky rattle when I start and switch off the engine. Have been told that the death of the clutch on a Puma would be sudden and it won't go thru the slipping phase. Don't want to get stranded but also don't want to go for a replacement unless I absolutely have to. |
Only had to change 2 clutches on Puma's Both 90's both early ones 07/08 models
Both just rattled on tickover, never slipped, just the plate springs rattling California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17916 ![]() ![]() ![]() |
In my experience a Puma driven plate lasts about 50k miles before the permanent set on the springs becomes sufficient to warrant replacement. Much above that and you start to run the risk of a spring falling out and making for a much larger bill.
my clutch was replaced at 7k for rattling, it however appears they will rattle for a long time before they fail DEFENDER 90 TDCI XS,
