![]() | Home > Maintenance & Modifications > jasong110 |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
You after Jason?
http://forums.lr4x4.com/index.php?showtopic=75339 I've emailed him this thread |
emma110 Member Since: 12 Apr 2015 Location: devon Posts: 3 ![]() ![]() |
That's the guy yes! Thank you
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3796 ![]() ![]() ![]() |
I don't think much of them.
Reason?....because they are on the inside of the vehicle by which time the heat has got in. We have VERY hot sun in Aus, so I devised my own method to keep the sun off the dash etc when the vehicle is parked. Simply get a roll length of UV resistant rubber sheet, cut it to the size of your windscreen with a "tab" on each end to slip into the door opening to hold it in place. Costs virtually nothing & does a top job. Pickles. |
Thanks - this is more to block the light for the odd camping trip! Will probably be raining knowing England!
jasong4110 Member Since: 19 Oct 2009 Location: Henley On Thames Posts: 268 ![]() ![]() ![]() |
How may I help you? The blinds were made from thermal camping mats.
