Home > Puma (Tdci) > LED Rear Indicator Issue
Landyawd
England 2011 Defender 90 Puma 2.4 HT Java Black
OK so I am currently fitting a WIPAC LED light kit to my 2.4tdci....
All the lights are working except the nearside rear indicator I have installed the new relay supplied in the kit.
Paddocks kindly sent me out a replacement unit, still does not work....
I have put the old unit back on and it works fine.... Shocked
So with my limited knowledge im guessing its not a wiring issue as far as i can tell, the relay has been fitted and im presuming I have not got 2 faulty units....
Any Ideas, have i missed something silly?
Post #413543 3rd Apr 2015 5:32pm
munch90
wiring wrong way round
leds only work wired one way
so try swapping wires round in that light plug
Post #413546 3rd Apr 2015 5:51pm
As Munch mentions that'd be most likely.
Failing that, remove clean and refit earth strap and bolt for rear lighting on the transfer box.
The first suggestion is most likely though.
Could either be the lights you have wired opposite or maybe someone fitted another plug on the Landy with the wrong polarity.
Issue wouldn't show with an incandescent bulb as polarity doesn't matter but with LED's it does.
Post #413578 3rd Apr 2015 7:31pm
leeds
Before swapping wiring around, remove one of the working indicators and fit the 'non working' indicator.
If 'non working' indicator suddenly works it is a polarity issue.
Can be slightly awkward to change wires in an ecoseal connector but spare connectors are only a couple of pounds.
Brendan
Post #413595 3rd Apr 2015 8:07pm
munch90
did you find problem ?
Post #413774 4th Apr 2015 4:56pm
Landyawd
Ok well after a bit of a hectic weekend I finally got round to having another look....
Thank you all Bow down
The wiring was the wrong way round. I traced back to 2 bullet connectors and swapped them over. Weirdly the bullet connectors were taped up with. Electrical tape. Not sure if someone has played with them before... If not its just a standard defender wiring thing.
Anyway thanks again all Smile
Post #414072 5th Apr 2015 10:16pm
