Home > Maintenance & Modifications > Nakatanenga Antenna?
Page 1 of 4 1234>
ZeDefender
Just got a newsletter advertising the Nakatanenga (Hirschmann) antenna. Has anyone had experience with one?
My standard telescopic LR one is okay but has been knackered twice (once through vandalism), so I'm considering an upgrade. For 90 Euros, though, it has to be worth it...
Matt Tell someone you love them today because life is short.
Post #411497 27th Mar 2015 7:37pm
leeds
Hi Matt, I know exactly what antenna they are using. We have the same on two of our Defenders and they work well.
Brendan
Post #411505 27th Mar 2015 7:54pm
farnley
Germany
also got the mail and looking at with interest , so let me know ZeDefender if you take the plunge
Post #411514 27th Mar 2015 8:26pm
Pickles
What do these look like?
Pickles.
Post #411534 27th Mar 2015 9:42pm
I got it too, some interesting products there.
Some of them I've known about for a while. Whistle
Post #411535 27th Mar 2015 9:43pm
Thumbs Up
Post #411538 27th Mar 2015 9:47pm
ZeDefender
Brendan
Cheers Brendan. I knew they'd be tough, it was good reception I was concerned about (I've had bad experiences before). Thanks for the info - looks like another Defender purchase is due Whistle
Thumbs Up Tell someone you love them today because life is short.
Post #411560 27th Mar 2015 11:12pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Do you stock these Brendan?
Post #411585 28th Mar 2015 12:35am
leeds
Embarassed I made a mistake on the last pallet order which arrived yesterday.
I forgot to include them Embarassed
We have another delivery next week so will see if I can get them included in that order.
We get regular deliveries from Nakatanenga, so if it is on their websites we can supply it.
Brendan
Post #411590 28th Mar 2015 1:08am
ZeDefender
I just ordered one so I'll give feedback in a few days Thumbs Up Tell someone you love them today because life is short.
Post #411601 28th Mar 2015 6:18am
kmac
Is the Nak aerial amplified?
Post #411650 28th Mar 2015 11:21am
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
I don't think the Nakatanenga (Hirschmann) antenna in the advert has integrated booster.
Have a look at the Blaupunkt 7 617 495 224 Autoflex aerial, it's a Universal, short-style wing mount aerial with integrated booster amplifier for AM/FM raido.
http://www.bluespot.co.uk/car-audio.aspx/7617495224-aerial
http://www.blaupunktdirect.co.uk/antennas-...erial.html
http://www.blaupunktdirect.co.uk/antennas-aerials.html?subcats=Y
Post #411680 28th Mar 2015 1:14pm
munch90
the bosch autoflex is the one I used , seems good
but the hole in the wing is too big to direct fit , but I used part of the standard aerial base and fitted ok and you need 12v feed for built-in booster
Post #411684 28th Mar 2015 1:36pm
gilarion
Nakatanenga Hirschmann radio antenna for Land Rover Defender ruggedness for off-road use We use a proven Hirschmann antenna and produce a multi-part stainless steel and aluminium mounting to fit into the original mounting hole in the Land Rover Defender, Specifications: antenna length: 47, 5 cm cable length: 133 cm material antenna: glass fibre, black material base: stainless steel and aluminum frequency range: 0.15-6.2 MHz / FM 87,5-108 MHz the visible part of the holder is in stainless steel .
Hirschmann radio antennas are a great brand and I am sure that Nakatanenga do a great job with their multi-part stainless steel and aluminium mounting and at £67.50 is probably good value. However if you wish to make your own mount the aerial whip can be found here complete with 1330mm low loss cable to DIN plug.
http://www.ebay.co.uk/itm/HIRSCHMANN-HIT-A...259e3f5078
 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #411690 28th Mar 2015 1:54pm
JWL
I've had a fair amount of success from this if you're on a budget http://www.ebay.co.uk/itm/Amplified-Replac...0559708597
But I've just noticed that this particuar one is "out of stock" at the moment
Post #411691 28th Mar 2015 1:56pm
Page 1 of 4 1234>
