![]() | Home > Puma (Tdci) > 2" OME Lift |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 ![]() ![]() ![]() |
Not personally but it's quite common. Any lift will change the angle the UJ has to work at, castor corrected radius arms can help re-align things but double cardons are often needed.
Have you fitted castor corrected arms as part of the lift? |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 ![]() ![]() ![]() |
Nor have I
![]() Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
Japseroony Member Since: 02 Jan 2008 Location: North East England Posts: 852 ![]() ![]() ![]() |
They were fitted at the same time as the 2" lift - QT's with a 3 degree correction, which from what I gather makes matters worse on the front which is why I have had to go for the double cardon front prop ![]() I think a wide angle rear should sort out the vibration from the rear and this has been mentioned by Cheviot 4x4 as well as Devon 4x4 - so more spare parts on the garage floor ![]() |
Hi Andrew, When I took the front prop off you could see that the joints were rubbing so whilst I think the wide angle will help you may still need a double cardon prop. Hows the Bell remap doing? He did mine about a week ago and mentioned it was the same as yours - much more torque but somewhat more thirsty now ![]() |
My MPG has increased from 16 - 18 to 24 -26
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8471 ![]() ![]() ![]() |
if you have castor corrected arms you will need the DC front prop as the diff is corrected ie closer to horizontal so the prop has a greater angle to work through when compared to running with std arms and NO caster correction where the diff will be nose up and hence a smaller angle for the prop to work through.
Plus 2" on the rear i would have thought would be OK with prop IF the shocks are with std mounting points and only +2". Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Hi; I`m new here. I was on the move to do the 2" lift considering already the change of the front prop. But, I`m surprised to know that also the rear prop has to be changed as well! cheers MK |
Its something to do with the fact that the TDCi engine and gearbox are mounted further back which means the rear prop is shorter thereby making the angles more acute ![]() ![]() Wish I had stayed with the standard suspension now ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
I lifted the suspension once and i vowed then NEVER again - i couldnt see the point and the additional grief
So my suspension upgrades are only ever HD suspension and gas dampers. I also learnt the hardway with buying aftermarket HD rear disco springs - never again, genuine HD springs for me - the HD's lasted HD like for about a year before becoming Stds ![]() |
Hi there: what setup did you use for front and back? thanks M Puma 110" SW ............................................................. Earth first. Other planets later |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 ![]() ![]() ![]() |
I have a 2 " OME kit and had the same bearing noise so devon supplyed a DC prop and curred the problem but my steering has gone a little sensative cant say what exactly but im going to try the castor correction to see if it sorts that .
I still have the same vibration noise coming from the rear maybe I need a rear prop now do I ![]() ![]() |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
It is that- have you tried having it aligned since the lift? If not, it is a good idea to do this- won't take it away completely but makes it bareable. Glyn |
