Home > Tdi > What Engine Colour
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
What Engine Colour
Hi guys
Ok i know i am not any way near this stage yet but just thinking ahead really buy what colour would you paint a fully recon'd disco 200tdi engine, obviously all areas properly cleaned before re-assembly.
as my 90 is finished in Bronze Green i was thinking BMC Engine Green for the block, Silver for the rocker cover, timing case, inlet manifold, and conversion / adapter plate, then Gloss Black for the pulleys and Black exhaust paint for the exhaust manifold, what do you think Very Happy Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #408879 19th Mar 2015 2:42am
I think your attention to detail is making my rebuild look a bit half-assed.
How about keeping it the original colours? QRZ 2e0vpf
Post #408886 19th Mar 2015 7:39am
cornish rattler
The engine i am hopeing to get has been stored under cover but think in a damp atmospher and all the ally stuff has slightly oxidised so thinking if i paint these parts i mite aswell paint the rest of the engine aswell but not all one colour Smile Graham
Post #408910 19th Mar 2015 10:10am
steventheplumber
England 1987 Defender 90 200 Tdi HT Keswick Green
Duck egg blue!
Post #408913 19th Mar 2015 10:38am
gilarion
Have it chemically cleaned then it would look like a brand new engine. Thier is also a shot blaster who uses crushed cherry stones not that far from you. it is located on the small industrail estate near where B&Q stockport is. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #408944 19th Mar 2015 12:36pm
munch90
be honest your always going to have problems getting paint to stay on a engine
get engine as clean as poss ,, good steam clean will do then wash off with thinners ( I wouldn't fancy having it blasted with any kind of grit etc due to it getting inside )
most important thing when painting is a very very thin coat first ( even so thin you can hardly see any colour to it ), the thin coat will soak in to any rust or rough casing areas
next coat bit thicker , then next coat thicker
if you paint first coat thick it will not last and will look terrible within 6 months
even after 2-3 coats you still don't want a thick coating , just light flick over coats and paint while other coats are tacky
painted quite a few race engines and its the only way to get it to look good and last as long as poss
Post #408956 19th Mar 2015 1:34pm
Fatboy Slim
Wales
We have a BUPI cleaner in our workshops (like a gigantic dishwasher for engines) if you can get the block to me I'll happily shove it in there for a few hours !. We paint the engines with a paint that is very similar to stove enamel.
Post #409066 19th Mar 2015 8:25pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
steventheplumber wrote:
Duck egg blue!
Exactly what colour I would paint it!
A genuine Land Rover engine colour Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #409068 19th Mar 2015 8:32pm
Lou Sparts
Most off the 200 Tdi,s I have seen the engine appears to be a goldy colour, were they that colour when new ? 2005 Td5 90 XS
Steve
Post #409076 19th Mar 2015 9:16pm
cornish rattler
Yeah i would amagine when i take the block for machining they will clean the block anyway and i can clean everything else but if not i will have to give it a good clean Smile Graham
Post #409148 20th Mar 2015 1:21am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Put it all together in one piece and spray it all massey ferguson grey machine enamel. Job done. Rhubarb and custard let fly with their secret weapon.
Post #409160 20th Mar 2015 8:10am
shaggydog
Who are you getting the block done by?
I would stick to original gold/brown-orange paint, sound boring but mine still has original paint on it after 24 years so can't be that bad!
One route to look at for the ancillary is having them wet blasted. We have a company near us who weirdly make exhausts but they can do wet blasting and the results are amazing. Much easier than all that boring polishing and less damaging. Brings aluminum up like brand new! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #409246 20th Mar 2015 1:41pm
cornish rattler
A company called Princess Engineering in Levenshulme, Manchester, used them for years so has my dad when he was alive aswell as a couple of firms i have worked for over the years aswell Smile Graham
Post #409434 21st Mar 2015 1:10am
Lotus_esprit_s1
My ROW defender had a replacement 300tdi engine re manufactured by Land Rover themselves in 2006. It came from the crate resprayed in thick silver paint all over, rocker cover and all. It all flaked off the head and rocker cover within weeks due to no primer used!
Post #412865 1st Apr 2015 4:52am
dailysleaze
Black in my opinion. Of all the things in the engine bay, the block is not the thing you probably want to accentuate. I think colour works best when used sparingly and in coordination, i.e. silicone hoses, etc.
Post #413471 3rd Apr 2015 12:38pm
