![]() | Home > Maintenance & Modifications > Rear Bumper Step |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 ![]() ![]() ![]() |
You mean a "NAS STEP" like this?
![]() Click image to enlarge I did this: ![]() Click image to enlarge A tow-bracket mounted step, and safari equip bumperettes... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
jeffsky Member Since: 11 Jan 2015 Location: Kent Posts: 34 ![]() ![]() ![]() |
![]() Click image to enlarge Thats it remove the old one and fit the new one you use the original wiring kit and tow ball if fitted its not a difficult job just done it on my 90 i fitted the NAS step only took a couple hours. if you do go for the NAS step make sure you get the one for the 90 as the mounting brackets are different from the 110 cheers Geoff 2.4 2008 defender sold |
Remove your current towing setup, fit tow step, and then simply bolt on your old towing ball
![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Tonyrec Member Since: 22 Feb 2014 Location: Lake District Posts: 137 ![]() ![]() |
Thanks for the input guys. Yes it is the NAS step I was talking about.
Looks fantastic so I think I will order one. ![]() |
GEllis Member Since: 21 Nov 2013 Location: Cornwall Posts: 58 ![]() ![]() ![]() |
I've just fitted the bowler rear steps. These allow the original drop plate hitch top remain, important for me as I tow a lot.great quality and easy too fit.
I do tow a single axle Ifor Williams trailer for the occasional 'tip' run.
Not sure after reading past posts if the NAS rear step would be suitable! |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
yes, good setup, but you need a swan neck type towball:
http://nakatanenga-tours.de/shop/article_A...SHT-090%26 WANTED: SII or SIII in max 1.5k |
Where are the measurements taken from to make these 90mm or 160mm lower - is it the lowest bolt hole on the backing plate?
![]() Here's my setup with the OEM rear step bumper: ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
From the middle of the 2x 90mm holes WANTED:
I might need a picture, I'm not sure what two holes you are referring to
andy---doe Member Since: 14 Mar 2015 Location: Yorkshire Posts: 188 ![]() ![]() |
Hi
I have just taken delivery of one this afternoon. They can be bought for about £300 but I paid £355 from the following link because they are LR main dealers and I wanted OEM genuine parts http://www.ebay.co.uk/usr/massey4x4?_trksid=p2047675.l2559 |
