Home > Puma (Tdci) > Puma 2.2 in low gear, no power
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
sorry if already tell ...
I was with my RR classic in the Pyrenees and no problem of power to go up in the mountains ...
I did buy a defender 2.2 in 2012, and if in low gear, no power at all, I did even prefer to go up in high gear what is not normal of course.
After some time I think that I did understand that the accelerator do not work the same in low or high
If I drive gentle, no power, I have to go on floor to have the sensation of power
If you understand my poor English, thanks for the answer
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #407986 16th Mar 2015 11:11am
YOLO110
Australia
I know exactly what you mean... mine is the same!
It seems like a completely different 'map' is being used in low ratio! No noticeable torque and the turbo 'boost' only seems available with full throttle at higher rpm...
I also ask, is this indeed 'normal'? Rolling Eyes YOLO... You Only Live Once...
Post #407993 16th Mar 2015 11:39am
Phil VM2.5
Hi YOLO110,
Or we are only 2, or my question is really stupid !
Regards,
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
1987 BMW GS80
Post #408318 17th Mar 2015 8:57am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
I think it's normal, in low gear the throttle sensitivity is different.
That was the case on the TD5 as well, some would even unplug or shunt the sensor on the t-box to get that type of throttle response in high gear as well...
Post #408841 18th Mar 2015 10:35pm
