Home > Puma (Tdci) > Windscreen Hinges & Bolts
MartinK
Hi
I've just purchased some Croytec windscreen brackets (thanks, K9F).
They'll be somewhere in the grasp of a courier heading North up the M6 now I would think Very Happy
However...two queries on the fitting thereof...
1. I was thinking I may as well add new (stainless hopefully) bolts. On older Land Rovers they were a stepped design as per the pic below. Anyone know the spec, or where I can get stainless ones?
2. Whilst I'm swapping them, should I squirt loads of Dinitrol Cavity Wax into the holes prior to refit (as you do with the door hinges on the pillars)? (query because of the unknown make-up of the material of the windscreen surround)
Pic of "old style" windscreen bracket bolt:
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #407177 13th Mar 2015 10:26am
MartinK
Aha just found a set on ebay
http://www.ebay.co.uk/itm/Land-rover-Defen...1388854534
Do these look right?
http://www.ebay.co.uk/itm/Land-rover-Defen...1388854534 Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #407179 13th Mar 2015 10:37am
K9F
Martin,
Two things here. The holes are blind, do not fill the holes with sealant as the sealant will have nowhere to go and you may damage the block or strip the thread on tightening. A slight smear on the threads is fine. Also use the butyl I have wrapped them in to cut yourself some gaskets. Again a small smear of sealant on the faces of the gaskets is fine.
The hinge blocks themselves are anodised alloy and as such I personally would be reluctant to use stainless ones but it is personal choice and I used the originals that were fitted to my vehicle with these blocks for several years without issue. I have now replaced the original bolts with stainless as my replacement blocks are stainless themselves. I could have thrown the original bolts in as well as they are just now sat on my workbench. Hope this helps.
Will take a picture of the bolts and post it up but the ones depicted do not look right. Use your originals. Thumbs Up
Here are my originals.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #407182 13th Mar 2015 10:46am
MartinK
Aha - thanks, K9F. I'll re-use the existing bolts I think.
WRT the bimetallic corrosion, I usually use ACF50 corrosion block grease, and it's all been ok so far.
Cheers buddy Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #407183 13th Mar 2015 10:54am
K9F
No sweat. Thought I'd keep the postage down by keeping the bolts...... Rolling with laughter
Just presumed you'd use your originals anyway. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #407185 13th Mar 2015 10:58am
MartinK
Thanks, mate, appreciated Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #407187 13th Mar 2015 10:59am
