Home > Technical > Microcat / OEM Snorkel / bolts
110SEB
My OEM snorkel has come loose where it attaches to the A-pillar.
The stealers drilled the holes slightly smaller than the bolts and added sealant. 2 years on and after the sealant drying and all the vibrations the tapped threads in the A-pillar holes have worn and the bracket is now loose.
My question is this: Does anyone have access to microcat to know which bolts they use, so that I can get replacements from LR.
I've tried Screwfix.com, but they're rubbish for car type stuff.
I can't find replacement bolts either that size or slightly bigger. I suspect they are M5 or M6 x 12mm
The problem is that there is virtually no room to get a nut in behind the bolt in order to tighten it up.
What have others done who have fitted their own raised air intakes?
Many thanks in advance.
Seb Thumbs Up
Pics below of the old bolt.
Post #35200 27th Jun 2010 10:01pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
would a rivnut work ?
Post #35201 27th Jun 2010 10:18pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
I'd be tempted to give Mantec a quick call. The self tappers seem to work themselves loose every few months, so they must be used to people wanting new ones. (I only caught mine in time and tightened them as I read a warning from alantd). Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #35203 27th Jun 2010 10:33pm
110SEB
Yes - good thinking Mr Flips. I'll give them a ring in the morning. Interesting that this seems to be an issue. I was surprised to see quite how little space there is on the other side of the A-pillar.
Rivnuts is a good idea too - but I lack the kit and would like to keep it as simple as possible.
Still keen to hear experiences and ideas...
Post #35204 27th Jun 2010 10:44pm
double cab happy
i've read some where that rivnuts can be done without the tool and just a bolt and a couple of washers, time consuming but for one or two that wouldn't be an issue.
http://www.fjr1300.info/howto/rivnut-tool.html
just an idea.
Post #35205 27th Jun 2010 10:54pm
mse
has anyone tried locktite or adhesive sealant when fixing Mike
Post #35208 27th Jun 2010 11:19pm
K9F
The OEM ones are usually rubbish anyway and rot out! I replace all the fittings of anything I buy with stainless replacements as soon as I can! It is always the cheap fixings that ruin a good product usually! If you've a steady hand and a cobalt drill small enough purchase some stainless hex head self tappers, drill the heads across the flats fit them and then using steel wire wirelock the heads together, guarantee they'll not undo without cutting the wire! Alternatively Loctite 221 should hold, but no guarantees with that method I'm afraid! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #35209 27th Jun 2010 11:47pm
110SEB
Just spoken to Mantec who are exceptionally helpful.
They are sticking two replacement self-tapping bolts in the post free of charge. They suggested Loctite as well.
We'll see how I get on. I'll post what happens...
Post #35253 28th Jun 2010 1:43pm
110SEB
Well, the kindly donated Mantec bolts arrived yesterday and I have just found out this afternoon that it's the holes in the screen frames that have rubbed as the old bolts wore loose - as a result the new ones don't fit and so don't hold the RAI bracket tightly (or at all in fact). I've done a patch job with silicone sealant and some Loctite threadlocker, but will need to sort it properly.
The problem I have is that the hex head M6, M7 and M8 x 10 - 12mm are like hen's teeth. Screwfix - nothing nor any of the other usual suspects. I'm going to ring Mantec again to see if they have any bolts as short but fatter to solve the problem, but failing that do you guys have any ideas of where i could source some? I've Googled and hunted but nothing.
Last solution is to remove the RAI altogether. I'd rather not.
Post #35540 3rd Jul 2010 7:43pm
fekete
I use these guys they seem to have everything you need
http://www.leytonfasteners.co.uk/index.shtml NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #35542 3rd Jul 2010 8:19pm
mse
Just go into a proper motor factors like unipart automotive, they will have the bolts or be able to order them Mike
Post #35549 3rd Jul 2010 10:53pm
110SEB
The Mantec replacements were useless. The **** at the stealership who fitted the RAI obviously used a 6mm drill bit to make the hole for the 6mm non self-tapping bolt. Hence the failure after time.
After MASSIVE amounts of hunting for a suitable bolt/screw, I have found it - a 6mm self-tapping radiator screw with washer from Autopart in Chelmsford.
Solid as a rock (so far) with thread locker and silicone sealant.
If anyone ends up having this wobbly loose OEM/Mantec RAI windscreen problem, I have a box of the perfect replacement bolts for the rubbish put in the box with the RAI. PM me and i'll stick some in the post.
Over and out.
Post #36484 17th Jul 2010 5:25pm
