Home > Puma (Tdci) > Running Lean
johnbain
Running Lean
Can anyone tell me a reason for my 2.2 running lean Range rover td6
defender2 xtech
Post #401907 25th Feb 2015 7:29am
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Technically I don't believe that it is possible for a diesel to run lean. Their engine speed is determined by fueling and load. If it was underfuelling then the revs / power would be down.
What are the symptoms?
Jonno
Post #402540 26th Feb 2015 9:17pm
grafty99
+1
Diesels can't run lean, less fuel just equals smaller bang on a diesel 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #402552 26th Feb 2015 9:39pm
LR90XS2011
why do you think it is running lean? DEFENDER 90 TDCI XS,
Post #402569 26th Feb 2015 10:21pm
Caterham
Years gone by I would agree with not possible.......
These days I would have thought it was very possible -but hopefully someone in the know can confirm?
Post #402643 27th Feb 2015 9:31am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Maybe his Puma has started giving 50 mpg, and he canīt work out why Very Happy 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #402663 27th Feb 2015 10:42am
johnbain
Mmmm wild card your funny Rolling with laughter your so helpful not Range rover td6
defender2 xtech
Post #402789 27th Feb 2015 5:15pm
johnbain
lr90 the tail pipe is white ish to golsden brown never seen it on a diesel before and ive got a slight over run . someone has said it might be a faulty air flow meter and i have had problems with this in the past . Range rover td6
defender2 xtech
Post #402829 27th Feb 2015 7:18pm
LR90XS2011
lots of modern diesels run light coloured exhausts I think its the addition of a cat and pdf that causes it with much less soot getting to the tail pipe , take a look at new MBs and Audis, your MPG is the best indication if you manage between 25 and 32 mpg it will be about right. DEFENDER 90 TDCI XS,
Post #402865 27th Feb 2015 8:26pm
Wild Card 90
So having got the funny dealt with, Iīll try helpful... What about temperature? Is the motor running hotter than previously? Temp is difficult to judge with the standard gauge. Do you have access to a scan gauge? 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #402899 27th Feb 2015 9:44pm
Jonno
All diesels run with an excess of air, they don't run at a predetermined ratio unlike a petrol, which runs at stoichiometric air , fuel ratio.
There is no throttle and the power output is simply defined by fuel in. You won't get a situation like a petrol where its overheating etc, due to lack of fuel..... It'll just run slower with less power.
Jonno
Post #402901 27th Feb 2015 9:48pm
johnbain
I ve decided put it in for a full health check just in case there is something amiss I thought some folk might of had this before but I ll let you all know what the result is thank you a all for your response on this . Very Happy Range rover td6
defender2 xtech
Post #402930 27th Feb 2015 10:54pm
martinfiattech
2.2 = DPF, Less soot of course, it`s gona have a cleaner exhaust. Excuse the spelling I`am better with spanners and wires.
Post #403367 1st Mar 2015 3:52pm
