Home > Maintenance & Modifications > Soundproof/Insulate quick advice?
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Hi,
My new Defender arrives next week. ( 110 USW)
Im keen to start in the loadspace with something to improve sound deadening and protect side panels from moving loads.
Reading the net leaves me a bit confused??
Do I need sound deadening pads first?...then insulation?..then carpet/rubber?
Is Dynamat ( or similar) a one hit solution?
Do I need to cover every square inch of bare metal?
Is it a different solution on Floor? sides?and roof?
Any help or experience welcomed. I want to do it myself and I want to do a "good" job without going completely over the top.
Thanks
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #401415 23rd Feb 2015 4:31pm
MartinK
Most of us use a combination of NoiceKiller, Dynamat & Carpet.
On the rear tub, I have NK under the carpet. Behind all the side panels I have Dynamat.
Not done anything behind the roof lining yet.
I have TGE panels as well because mine's a USW
Very happy with the result. Can have a normal conversation at 65mph Thumbs Up
Also a Nakatenanga loadspace mat to keep the carpet clean Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #401418 23rd Feb 2015 4:41pm
You don't 'need' to cover everything, but we do.
We use 'Dynamat' or 'Skinz' dependant on the clients preference / budget (I personally can't tell the difference when driving in a vehicle between them) - These are a foil sheet with a 'bitumen' type black sticky backing, it is this that is applied to the bare metal (be sure to degrease the metal first)
We then apply a layer of 6mm neoprene, again from either manufacturer to all floor areas and rear seatbox / barrel sides / van sides (which we then carpet)
The lines in the carpet is our valeter being arty ! :roll:
Post #401419 23rd Feb 2015 4:41pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Blimey. Is that leather trim in the hard top back?
Post #401502 23rd Feb 2015 9:07pm
Of course ! Cool
Post #401516 23rd Feb 2015 9:37pm
